2007 Vstar 1100 custom - Starter Clutch Issues - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
post #1 of 17 (permalink) Old 03-06-2012, 10:33 PM Thread Starter
The bike has 13k miles
So i have determined that my starter is working and i still have the problem with the starter free spinning when installed.
I'm guessing now it's the starter clutch
My question is, i read somewhere that i should also replace the gear idler 2 and the bearing, will i be able to check if i need to replace the gear idler 2 after i take apart the bike? will the damage be visible? i'd like to hope that it is still in ok shape and only the bearing and starter clutch needs to be replaced. That will save me $100
anything else i need to check or look into when attempting to replace/repair it?
i do have short custom pipes, does that play an issue? i don't think the bike has been jetted since the pipes have been put on.
i read i need to check the timing on the flywheel and the tps?
appreciate your time and any input you can give
Chillbman is offline
post #2 of 17 (permalink) Old 03-06-2012, 11:04 PM
SparkyD's Avatar
15k on my 2005 and no problems with starter (yet)
There is a thread in this forum that goes into good detail of what parts need to be replaced. Did you do a search for that thread?
Flatulence is natures way of reminding us to laugh at ourselves.
The views expressed above are those of the author and may, or may not, express the views of those around me. Any resemblance to persons living or dead is purely coincidental. No animals were harmed in the typing of this messege.
'05 V-Star 1100 Midnight Custom
slightly modified
SparkyD is offline
post #3 of 17 (permalink) Old 03-06-2012, 11:12 PM Thread Starter
well, i'm used to older bikes.. and i didn't know these new bikes start to break if you give any throttle when you start them up
i'm pretty sure i saw the thread you're referring to and that is where i got most of my info, i'm just wondering whether or not you can tell if the idle gear 2 is damaged by just looking at it.
its 100% i need to replace my starter clutch due to me giving it throttle when starting and maybe my tps is off
post #4 of 17 (permalink) Old 03-07-2012, 09:43 AM
dave star's Avatar
The idle gear 2 will be bad, You can tell by looking at it with it has any marks on it its bad.Heres a picture of a bad 1 and picture of parts you need.Yamahapartsnation.com has the kit for $295.Mine went out at 12000 miles. you need to replace the 3 parts behide the fly wheel thats the starter clutch if you don't replace all 3 parts it won't last.It might be cheeper to buy the kit
Name:	starter clutch.jpg
ID:	1508   Click image for larger version
dave star is offline
post #5 of 17 (permalink) Old 03-07-2012, 11:38 AM
DYNA118's Avatar
Tim B @ Metric-Magic.com has been dealing with these for years and has the best prices for the parts.
DYNA118 is offline
post #6 of 17 (permalink) Old 03-07-2012, 12:00 PM Thread Starter
thanks Dave, but i believe its 295 for just the starter clutch itself, the gasket is $20 / idle gear 2 is $100 / gasket is $7
i'd really like to avoid getting the idle gear 2 if possible to save $100
if you could show me a direct link to the 2007 1100 vstar custom starter clutch kid, i would appreciate it. i cannot find it on that website, just the individual parts that add up to $450+
post #7 of 17 (permalink) Old 03-07-2012, 12:06 PM Thread Starter
thanks, i requested a quote from him
post #8 of 17 (permalink) Old 03-07-2012, 01:20 PM
dave star's Avatar
Sorry about that Chillbman,Where i bought mine its $404. for the kit.I got mine for $350.They up the price $54.
07 v star 1100 Sliverado-chrome accessories-switch covers-master cylinder cover-fender tips-horn cover-headlight viser-skull levers. Trunk-extra break an running lights-Micks ssd kit-bikers choice tach-dwg speakers-chubby kit-lightbar--cobra pipes an crashbar-mustang set
post #9 of 17 (permalink) Old 03-07-2012, 01:42 PM Thread Starter
Metric magic is charging 425 for everything
i heard that the starter clutch now comes as a kit with the bearing and idle gear 2
#99999-03908-00 part number
post #10 of 17 (permalink) Old 03-07-2012, 01:48 PM
dave star's Avatar
Thats the kit i bought .The picture on my first post shows all the parts you get,I bought mine from cucamanga yamaha
