Mixing brake fluid brands? - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
post #1 of 6 (permalink) Old 05-16-2017, 08:04 PM Thread Starter
I have a 2006 V-Star 1100. I'm about to do a brake bleed and will likely need to add brake fluid during the process. The Clymers manual says to always use DOT 4 brake fluid but goes a step further and says to always use the same brand of brake fluid and to never mix brands, as there may be something different between the two brand formulas. Is this really a concern?
openair is online now
post #2 of 6 (permalink) Old 05-16-2017, 08:10 PM
DOT#4 is DOT#4 no matter who makes it
post #3 of 6 (permalink) Old 05-17-2017, 01:24 PM
joelg's Avatar
I think the bigger concern is why would you have two different brands - ie. is one an old bottle you have lying around? If it is an open bottle you should dispose of it and use a fresh bottle as brake fluid is hygroscopic and will go bad.
Joel
2006 Roadliner Midnight XV1900
joelg is offline
post #4 of 6 (permalink) Old 05-17-2017, 02:08 PM
NGM
Lifetime Premium
NGM's Avatar
I would do a total flush if it were me. Does not take long then the problem if mixing is solved. :-) BTW I just did this on mine.
NGM is offline
post #5 of 6 (permalink) Old 05-17-2017, 02:21 PM
from what the manual is saying you would have to assume the factory put Yamaha brake fluid in the bike at the factory
and
thou shall not mix brands = you must buy Yamaha brake fluid
unless you drain out all the old stuff.
I agree with Pauli Dot4 is Dot4.
If it bothers you drain it all out - there is no way a flush can be a bad thing.
post #6 of 6 (permalink) Old 05-17-2017, 05:42 PM Thread Starter
Thanks everyone! Much appreciated. Sounds like pretty much nobody thinks mixing different brands of DOT 4 is a problem. I might do a brake flush, but if it's not a problem to mix brands, then it's not a problem.
