V Star 1100 Exhaust Modification - Page 2 - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
post #11 of 20 (permalink) Old 10-15-2009, 03:12 PM
papagrizz's Avatar
Originally Posted by 081100vstar View Post
Yes you would need to take it into consideration when doing the DIY RAM air mod anything that can potentially changed the air/fuel ratio. Things like opening up the exhaust and freeing up the intake will make it run different. Now i also had the DIY exhaust mod for a long time before i bought V/H classic 2 and i never experienced this lack of power you speak of. However if you rejetting with both mod's then i would consider using a 17 in front and a 14 in pilot. That is alittle smaller than my friend went on his when we opened the exhaust up alot and dragons breath intake we went with a 19 and 16. But those number we guesses that turned out to be good.
Thanks brother, that answered my question...at least now I have a starting point to go by....
Live life to the fullest and be careful while doing it!
DE OPPRESSO LIBER
papagrizz is offline
post #12 of 20 (permalink) Old 12-25-2009, 02:25 AM
vstar23's Avatar
I have 2000-Vstar 1100 Custom
I just want a simple exhaust change, make stock a bit louder, but dont want to damage engine.
have you had good results from the phelps mod shown below?
What i have read seems positive so far.
http://www.vstar1100.com/jack_phelps/vstar/exhaust.htm
Will the bike work without backfiring and retain AIS?
Any issues with air/fuel ratio changes or overheating of engine/valves. i really dont want to make carb chages and ais changes .
Thanks for your input
vstar23 is offline
post #13 of 20 (permalink) Old 12-25-2009, 12:21 PM
081100vstar's Avatar
Well before I put my V&H slip-ons I had used the mod with the bike for over 3000 miles and I retained the AIS system I had alittle backfiring but overall good sound i only switched because i wanted a different look to the bike.
081100vstar is offline
post #14 of 20 (permalink) Old 12-26-2009, 07:54 AM
vstar23's Avatar
thanks for the input
vstar23 is offline
post #15 of 20 (permalink) Old 08-01-2010, 10:18 AM
Mod on 2006 1100
I am considering doing the Phelps modification on my 2006. I noticed in the thread there was a specific set of instructions for the 2006 model. However, in the instructions it doesn't describe once the baffle is out if you still place the short piece of pipe into the exhaust. Can someone give me some advice?
d
dk13682 is offline
post #16 of 20 (permalink) Old 09-10-2013, 04:40 PM
Cruzerbill's Avatar
2009 1100 Exhaust Mod
Originally Posted by chitownfl View Post
Has anyone done the following exhaust modification on a 2006 (or so) 1100 V Star? http://www.vstar1100.com/jack_phelps/vstar/exhaust.htm
It is basically cutting out the baffles. I am thinking about doing this until I can afford real aftermarket pipes and was looking for stories of anyone whom had already done this.
Anyone have experience with doing this mod on a California 2009 1100 Classic? I did the mod on my old 2002 Classic and all went well, but rumor has it there is a catalytic converter in the later model years and I'm not sure what effect the mod would have on the cat, or if there is any difference in the modification procedure itself?
Cruzerbill is offline
post #17 of 20 (permalink) Old 09-10-2013, 04:52 PM
farmalldanzil's Avatar
I done this mod to my 06 1100 and my 07 650 without one problem.
the 1100 is at about 28,000miles and the 650 is at about 35,000miles. I removed the AIS from the 1100 but not the 650.
farmalldanzil is offline
post #18 of 20 (permalink) Old 09-14-2013, 09:07 AM
Did this to my shadow vlx and didnt have to do anything at most u would have to adjust the air fuel mixture screw on the carbs i would b very surprised if u had to rejet
catfish1978 is offline
post #19 of 20 (permalink) Old 09-14-2013, 01:41 PM
Cruzerbill's Avatar
Thanks for the info farmalldanzil and catfish1978!
post #20 of 20 (permalink) Old 10-08-2013, 12:12 PM
quenston's Avatar
I done this with my 07 1100 classic with a plasma cutter made it louder with no adjustments needed
New owner of 2007 V-Star 1100 Silverado
Joshua 24:15
15And if it seem evil unto you to serve the LORD, choose you this day whom ye will serve; whether the gods which your fathers served that were on the other side of the flood, or the gods of the Amorites, in whose land ye dwell: but as for me and my house, we will serve the LORD.
quenston is offline
