05 1100 Vstar Backfiring on Deceleration - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
post #1 of 7 (permalink) Old 10-12-2010, 03:45 PM Thread Starter
After my 05 vstar sat for a few months it decided it was not going to run. I took it to my local yamaha dealer for service. I had the battery changed, fluids drained, plugs changed, and carbs cleaned. The mechanic states he now has the bike running great execpt that it backfires on deceleration. It has never done this before. It has hard chrome shot gun pipes and was jetted when the pipes were put on back in 05. I have never had a problem with it backfiring until now. It has been in the shop for 9 weeks and the mechanics are stumped. They cannot find any air leaks and have replaced a bad seal. Can anyone suggest anything we are missing?
GreggG is offline
post #2 of 7 (permalink) Old 10-12-2010, 05:47 PM
Fulltilt1's Avatar
Have them open your PMS (primary mixture screw) about 1/4 to 1/2 turn.
GW
2005 1100 Custom
Speedster Slashdowns
ORKed 5/16" Lines
PODs K&N RU-600s W/PCV
PCS XXX/2 cams
AIS Removed/Plugged
Pro-1 Tach
TPS Connected
Memphis Shades Bullet Fairing
Progressive 465 rear
Fulltilt1 is offline
post #3 of 7 (permalink) Old 10-13-2010, 10:39 AM Thread Starter
Thanks, I will foward this on. Fingers crossed that this will help and hopefully stop us from pulling what little hair we have left out.
GreggG is offline
post #4 of 7 (permalink) Old 10-13-2010, 04:34 PM
Fulltilt1's Avatar
With the stock airbox configuration /plumbing you should be jetted here.
115 F 112.5 R
No change to pilots
PMS about 2.0 turns out.
Stock needles (plastic, spacer,clip and washer. point to fat end)
(These are Mikuni #s)
If it was jetted with a dynojet kit your numbers will be different.
GW
2005 1100 Custom
ORKed 5/16" Lines
PCS XXX/2 cams
AIS Removed/Plugged
Pro-1 Tach
TPS Connected
post #5 of 7 (permalink) Old 10-13-2010, 08:28 PM Thread Starter
Thanks, i stopped by the shop today and questioned them about the pms. they agreed and were in the process of tweeking it but have not been able to dial it in exactly. They have gotten the backfires to a minimal and they are now only occuring while going down hill and decelerating spuraticly where as it was constant on deceleration, but they are saying even though they got it to the point of spuratic when the back fires occur they are saying they would not consider it a normal sound. (not really sure what they mean by that) The have contacted yamaha hq for additional assistance but no luck yet. it was jetted back in 05 when the pipes were put on.i believe it was with a dynojet but i will have to go back and check the paper work. I don't remember exactly. It has a stock airbox. It has been running great prior to letting it sit. Do jet kits go bad after several years of running with no problems? The mechanics are telling me that they do not believe it to be a carb problem anymore, yet they cannot find any air leaks or anything else out of the ordinary.
GreggG is offline
post #6 of 7 (permalink) Old 10-14-2010, 10:31 AM
Fulltilt1's Avatar
I think this is what they were refering to. Per Mikuni:
http://www.mikuni.com/fs-tuning_guide.html
This is why most people tune the PMS a little rich as it softens the abrupt change in the mixture. It also helps to disconnect the AIS as it is in reality just an air leak into your exhaust. The AIS (Air Induction System) pumps air into the stock exhaust to help clean up emissions but will increase the likelyhood of backfiring in an open exhaust.
I have both done and have no backfiring issues.
GW
2005 1100 Custom
ORKed 5/16" Lines
PCS XXX/2 cams
AIS Removed/Plugged
Pro-1 Tach
TPS Connected
post #7 of 7 (permalink) Old 10-14-2010, 01:05 PM Thread Starter
Thanks, I will print all of this info out and bring it to the shop. Thanks for your help. I will keep you posted.
GreggG is offline
