2009 V-Star 650 Classic Passing Lamps - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
post #1 of 7 (permalink) Old 10-30-2010, 02:11 AM Thread Starter
mole2's Avatar
I bought the Yamaha passing lamp kit and mounting bar for my 2009 V-Star 650 Classic. I went to install them today and after removing the windshield, removing the headlamp, disconnecting the wires, removing the old mount, removing the turn signals, snaked all the wires and went to mount the turn signals on the new mounts and....the mounts are too big. There is no way to mount those turn signals on that size mount. Does anyone know if there are smaller mounts available. I wound up putting everything back so it was like a dry run. lol Help!
2009 V-Star 650 Classic Pearl White
2007 Suzuki GZ250 Black (sold)
mole2 is offline
post #2 of 7 (permalink) Old 10-30-2010, 09:57 AM
Fulltilt1's Avatar
Access a web based IPC (Illustrated Parts Catalog) and look for a part number. Several parts vendors provide them.
GW
2005 1100 Custom
Speedster Slashdowns
ORKed 5/16" Lines
PODs K&N RU-600s W/PCV
PCS XXX/2 cams
AIS Removed/Plugged
Pro-1 Tach
TPS Connected
Memphis Shades Bullet Fairing
Progressive 465 rear
Fulltilt1 is offline
post #3 of 7 (permalink) Old 10-30-2010, 08:51 PM
I took a Dremel tool and opened up the turn signals to fit the mounts. This was on an 1100 Silverado.
ridgwayrescue is online now
post #4 of 7 (permalink) Old 10-30-2010, 09:10 PM
Tonydtiger1971's Avatar
This sounds like a good answer.
Tonydtiger1971 is offline
post #5 of 7 (permalink) Old 11-01-2010, 12:17 AM Thread Starter
mole2's Avatar
Might you have a link to one?
mole2 is offline
post #6 of 7 (permalink) Old 11-01-2010, 03:43 PM
Fulltilt1's Avatar
http://www.yamahapartshouse.net/page.../1/Yamaha.aspx
http://www.partforyamaha.com/pages/p.../2/Yamaha.aspx
GW
2005 1100 Custom
ORKed 5/16" Lines
PCS XXX/2 cams
AIS Removed/Plugged
Pro-1 Tach
TPS Connected
post #7 of 7 (permalink) Old 11-07-2010, 05:44 PM Thread Starter
mole2's Avatar
Well, it seems that what the problem was the instructions don't mention anything about removing the rubber shock mounts inside the turn signals. I removed them from each of the turn signals, opened the clamp up slightly with a screw driver and they slid on - hard - but they slid on. They should tell you that in the instructions. Got them all together today and all is well.
By the way, thank for your help Fulltilt. I tried those links and others and nowhere can I find the passing lamp parts listed but now it irrelevant.
mole2 is offline
