2003 1100 custom starting problems - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
post #1 of 7 (permalink) Old 05-30-2012, 09:43 PM Thread Starter
Unhappy 2003 1100 custom starting problems
V-star 1100 custom has a start problem.... i think
can anyone tell me what's going on with my bike. is it just the starter. i bought it like this, but after adding a new battery it went away. now it's back.
sometimes if will do this over and over again. so i stop after maybe 4 tries, and then do it again. the other night it would not go.
please watch the short video.
fah_kinright is offline
post #2 of 7 (permalink) Old 05-30-2012, 09:55 PM
aide's Avatar
Here is a link to look at and I am sure many other will jump in.
http://www.sloneservices.com/SilverB...08.htm#Starter
aide is offline
post #3 of 7 (permalink) Old 05-30-2012, 10:53 PM
What does the battery voltage drop to when you crank the starter?
Have you check the reg/rec to see if it's charging? Also, have the battery load tested.
--- Striping, lettering and paint by Sick Mick 6* Tree - 2" extended forks 21" front wheel - HK Sideburners - Progressive rear shock Pods Sick Mick solenoid delete - Spring seat - Seams rolled on the fuel tank...and a lot more
Sick Mick is online now
post #4 of 7 (permalink) Old 05-31-2012, 04:31 AM
I have the same problem with my 04, the dreaded starter clutch. right now I am going as long as I can before fixing it. mine has been doing it for 6 months. dont give it any gas or choke from the start. once it catches give it gas and engage choke if needed.
2004 1100 silverado
Rickt is offline
post #5 of 7 (permalink) Old 05-31-2012, 04:04 PM Thread Starter
had the battery tested by the vendor and it's coming back perfect.
what would be the reg/rec?
post #6 of 7 (permalink) Old 05-31-2012, 04:05 PM Thread Starter
how do you know how long it can go?
how do i know it it's just the starter or the starter clutch
post #7 of 7 (permalink) Old 05-31-2012, 04:18 PM
BTW...what is your idle set at? It sounds really low.... should be 950-1000 for proper oiling at idle.
So the battery checks out fine and doesn't lose any charge while in the bike? The reg/rec is like a voltage regulator. if it goes bad, you either over or under charge.
I'd remove the starter too. Look at the 2 long bolts holding it together to make sure they aren't twisted. If they are loosen them and twist everything back where it should be.
