Help Front Cylinder not firing - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
» Insurance
» Sponsors
» Our Partners
»ATV Reviews
»Motorcycle Games
Go Back   Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum > Motorcycle Models > V Star
Thread Tools Display Modes
Old 04-23-2010, 02:11 PM   #1
01vstr1100_nj
Default Help Front Cylinder not firing
Hi everyone,
New to the forum not so new to riding! After a 3 year hiatus from riding for various personal reasons I have decided to pick it back up again!
Here goes the problem - bike has been sitting for 3 years in storage with a full tank of gas. The bike would not turn over and after replacing the battery and finally figuring out that the ignition relay was shot I'm back in action.
The bike was running incredibly rough (most likely due to the old gas) and backfiring like mad shooting foot long flames out the pipe from the front cylinder. Also it wouldnt run without the choke on. Drained the gas, put super and some sea foam in the tank and bypassed the AIS system.
Now its idling fine and will run without the choke on but only on ONE cylinder! I am in the process of taking the carbs off for a thourough cleaning and will be pulling the plug to check condition. Any ideas on what other than clogged carbs could be causing this? It was firing before I bypassed the AIS and replaced the fuel. Is it possible that I burned a valve?
Thanks!
01vstr1100_nj is offline   Reply With Quote
Old 04-23-2010, 02:57 PM   #2
Fulltilt1
Fulltilt1's Avatar
Default
A good chance you washed something out of your tank and clogged the primary jet. Turn your gas off disconnect the line at your petcock and drain some into a glass container, before you clean your carbs. This will let you know that your gas supply is clear before cleaning carbs. Then clean and reassemble he carbs all should be well. I doubt you burned a valve with light running. Have you checked around your intake for a leak. cracked rubber boot?
Fulltilt1 is offline   Reply With Quote
Old 04-23-2010, 03:17 PM   #3
01vstr1100_nj
Default
Fulltilt thanks for the response. Fuel supply is clear - when I drained the almost full tank out it was flowing with no problem at all. Boots are both in great shape and were attached securely - I will be finishing removal of the carbs tomorrow morning so hopefully when clean will resolve the problem! Thanks again for the response!!
Forum Jump
1199 Panigale Forum Honda Africa Twin Forum Roadglide Forum Honda CBR1000 Forum Vulcan Forum Yamaha R1 Forum Yamaha R3 Forum
BMW Scrambler Forum Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
