I feel like a real n00b, but How do you get the cyl caps off of the V-Twin to change the spark plugs?
Is there a picture based how to on the net??
__________________
Regards,
Conley Shepherd
2005 V-Star 1100
'Hard Krome' pipes
K&N filter
Custom front turn lights
large saddlebags
engine accent lights
wide seat
Kuryakyn Tombstone LED rear light set
ORK 5/8 line
POD MOD
When I did mine recently I had to remove the seat and lift the tank a bit to get enough clearence to get the chrome caps off. Then I had to remove the left engine guard and floorboard to get room for the spark plug socket and extention with a swivel joint just to get the front plug out. The rear plug was only a few minutes to change but the front one took about 30 minutes. When you put the new plugs in, use a piece of aquarium hose on the top of the plug to get the plug started in the hole because they are deep down in the cylinder head. Also be sure to check the gap on the new plugs before you install.
__________________
02 Vstar 1100 classic
Samson Warloard Ripsaws
chubby air intake/maxmix pms screws
barons ork
kuryakyn isso grips
breakaway cruise control
pro one tach
oem passing lights
crome visors on all lights & signals
drag highway pegs
throwover saddle bags
sissy bar with rack
studded front and rear seats
studded gas tank bib with pouch
clocks for bikes- stem mount
Ram mount& hard wire for GARMIN GPS
Memphis Shades Batwing Fairing
Thanks, the plugs went in and gave a little boost. I got the iridium plugs. The old plugs didn't seem taught enough when I removed them. The front cyl plug had old oil around the outside and looked like the plug was fouled. The rear plug was fouled a littl;e, but not half as bad as the front. I think the problem was that the plug wasn't seated completely and allowe a little blow by over time.
Bottom line is that it runs good, no leaks and the dealer gave it his nod of approval. He took it for a spin around the block and said I only had to perform the maintenance stuff. Aside from the front tire, needing replacement soon, the bike is a real winner!
__________________
Regards,
Conley Shepherd
2005 V-Star 1100
'Hard Krome' pipes
K&N filter
large saddlebags
wide seat
ORK 5/8 line
POD MOD
Just changed the plugs on my 04 1100 custom, I read this thread first and was holding my breath, the service manual doesn't mention having to remove the seat or raise the gas tank. After wasting time pulling the wrong cover, (the one on the front cylinder with the screws), I pulled the correct covers straight off, used compressed air to blow out the cylinders, then was able to remove and replace both plugs without having to do anything else. Maybe the custom has a smaller gas tank or something? I also used a 'wobble' long extension on my rachet giving me more angle to work with, maybe that also made a difference.
After wiping the bike down and starting it to be sure everything seemed alright, I'm now ready and eager for the ride to work in the morning.
I love this tool and it saves the skin. I don't remove the seat ,tank etc. Alto on the front cyl I have to make room by removing the upper crash mount bolts.
You dont have to remove anything other then the decorative chrome covers thye like mentioned pull out and push back in. Once the cover is off and the spark plug boot is off its a straight shot to the spark plug, you dont even need a wobble or anything special.
__________________
2008 V-Star Silverado. K&N filter, airbox mod passenger floor boards, all light visors, ISO grips, Cobra slash cut mufflers and air bypass.
Got tired of dumping $$$ in my Harley went to a better bike.
Thanks to all for this timely post. I recently got the Clymer manual for my 03 1100 Custom and it referred to removing the tank. Glad I saw this before I dived into all that mess!!!
Buddy, I'm not sure what kind of engine guards you've got on there....but, removing the floorboard must have been just to get the guard off; it's no where NEAR the plug!
