Oil Temperature - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
» Insurance
» Sponsors
» Our Partners
»ATV Reviews
»Motorcycle Games
Go Back   Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum > Motorcycle Models > V Star
Thread Tools Display Modes
Old 09-23-2010, 11:35 AM   #1
Neil01
Question Oil Temperature
I have a 2007 Vstar 1100 Custom with an oil relo kit, I installed an oil temperature guage this spring and thought I would supply information for those who were interested.
I run synthetic Mobil 1 15w-50 oil
It takes a good half hour for the engine to achive operating temperature.
At 75 degrees air temp the bike runs at 175 to 180 degrees f.
At 90 plus degrees air temp the bike runs around 195 degrees f.
These numbers are around town and cruising at or below 55 mph. On the interstate around 70 mph the bike runs (depending on the air temp) between 200 and 210 degrees. The only thing I can think of is that the oil is running through the engine much quicker at highway speeds and does have time to cool as adequately as it does at lower RPMs.
I bought the guage because I was worried about engine temp when I got stuck in traffic but as it turns out the bike runs cool and there is no worries in traffic.
Anybody have any other thoughts on this?
Neil01 is offline   Reply With Quote
Old 09-23-2010, 12:22 PM   #2
oldbanjo
Default
I have a 02-650 Classic, on extremely hot days I have been checking my temp with a non-contact infrared thermometer, it's been running 160 deg F. I am running slow between 12 and 22 MPH with my dogs. I bought the bike used and know it has 10w30 syn, I've bought the correct syn oil but have not got the filter yet. I'm in no hurry because I hardly ever go over 45 MPH. Before winter I will change it.
oldbanjo is offline   Reply With Quote
Old 09-24-2010, 01:50 PM   #3
Fulltilt1
Fulltilt1's Avatar
Default
I've got one of the filler cap screw ins, that measures the air temp in the crankcase. Got it here.
http://www.sscustomcycle.com/product...star1100.shtml
__________________
GW
2005 1100 Custom
Speedster Slashdowns
ORKed 5/16" Lines
PODs K&N RU-600s W/PCV
PCS 10.6:1 pistons & XXX/2 cams
Jetted & PMS Tweaked 20.0/160.0 3.0 turns
Stock Needles with 1.09mm of spacer
Mic'ed and drilled #4 washer
AIS Removed/Plugged
Pro-1 Tach
Dyna 3000 Step 5/ 6500 redline
TPS Connected
6" Fwd Control Extension
Comfort Cruise Stiletto Seat
10,000 Monkeys throwing crap at the glass and this one thinks he's Picasso...
Fulltilt1 is offline   Reply With Quote
Old 09-24-2010, 08:15 PM   #4
Sugar Bear
Default
Sugar Bear, with that oldtimers brain, may have posted on this before, if so sorry, But guys ,there are times you don't want to know what you oil temp is Keep her runnin in the wind, you will be ok Run cool, Ride safe.
Sugar Bear is offline   Reply With Quote
Old 09-24-2010, 08:30 PM   #5
Fulltilt1
Fulltilt1's Avatar
Default
LOL I like to know my pressure and temp. That way I know if its time to find a cool beverage and a hot chica.
__________________
GW
2005 1100 Custom
ORKed 5/16" Lines
AIS Removed/Plugged
Pro-1 Tach
TPS Connected
Old 09-25-2010, 08:00 AM   #6
Neil01
Default
Try this site, high quality guages designed specifically for bikes.
http://www.motosens.com/english/f6c_e.htm
I have the temperature sending unit in the remote oil filter feed line so it is hot comming out of the engine.
Old 09-25-2010, 01:05 PM   #7
oldbanjo
Default
I'm not real concerned with oil temp on a bike that's air cooled, unless I've done something stupid and blocked the air flow. If I had a bike that was water cooled I'd be real concerned. I've had many wind shields and radiators busted while in my Pick up Truck, by rocks being thrown by on coming Tractor Trailers.
Old 10-10-2010, 07:21 PM   #8
Neil01
Default
Okay, so it was 86 degrees today so I took the bike out for a highway run... I ran 4,000 rpm's (73 miles an hours) for 30 miles. The oil temperature was 230 degrees F. Now this engine was designed by a bunch of smart folks and has run a bunch of miles since it’s creation with little issue so I am not so sure there is much to worry about. I do run full synthetic but this is really making me lean towards an oil cooler.
Any opinions are welcome…
Old 10-10-2010, 10:12 PM   #9
linerdave
linerdave's Avatar
Default Oil temp
Neil,
There are lots of folks out there that don't have an oil temperature read out and they do just fine. But, I did often think of an oil cooler when I had my 1100. Can't hurt if you have room with the filter relocation kit. Did I worry too much? Probably. Are you worrying too much?
linerdave is offline   Reply With Quote
Old 10-11-2010, 12:10 AM   #10
atomic drifter
Default Oil Temp
Hi Neil01,
I think you are on the right track with changing out your oil filter and taking measurements. I have an 05' 1100 Silverado with 22k that I installed an oil cooler and changed from Valvoline 10-40 to Castrol 10-40 simi-syn. This bike also came with an outside filter kit. I bought an infarared thermometer and measured 265 deg F on the outside at midpoint of the rear , right jug after running at idle for 20 min. Basically the temp was the similar before and after the changes. The bike runs great. The jury is still out as to whether there is any net increase in cooling efficency. I know a couple of things: 1. The 1100 gets hot sitting at traffic, I know this from the heat I start to feel between my legs when I am stuck in rush hour. 2. Hi grade oil (including zinc and phospherous additives) goes a long way in increasing engine longetivity, 3. There is a lack of specific information addressing performance of lubricant cooling modifications. 4. There is no public information related to systematic lubricant overheating resulting in engine failures. More later.
AD
atomic drifter is offline   Reply With Quote
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Ducati Forum Harley Davidson Honda 600RR Kawasaki Forum Yamaha R6
1199 Panigale Roadglide Forum Honda CBR1000 Vulcan Forum Yamaha R1
Ducati Monster Harley Forums Honda CBR250R ZX10R Forum Star Raider
Suzuki GSXR V-Rod Forums Honda Shadow Kawasaki Motorcycles Star Warrior
SV650 Forum BMW S1000RR Honda Fury Kawasaki Versys Drag Racing
Suzuki V-Strom BMW K1600 Triumph Forum Victory Forums Sportbikes
Volusia Forum BMW F800 Triumph 675 MV Agusta Forum Streetfighters
