Basic Wiring for generic passing lights? - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
» Insurance
» Sponsors
» Our Partners
»ATV Reviews
»Motorcycle Games
Go Back   Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum > Motorcycle Models > V Star
Thread Tools Display Modes
Old 05-18-2011, 12:42 PM   #1
SkatKat
SkatKat's Avatar
Default Basic Wiring for generic passing lights?
Hey all,
A friend of mine gave me a pair of generic 3 1/2" passing lights. (I think 35W bulbs). I still need to get 2 clamps to mount.
My question is, can I do a simple splice into the headlight wire or do I need to add a relay - switch etc..? I cant seem to find a definitive DIY on this.
I found this article, but not sure if it will work.
http://www.vstar1100.com/diy_passing_lamps.htm
Any info appreciated. THX
__________________
D & D
2006 Vstar 650 Classic
SkatKat is offline   Reply With Quote
Old 05-18-2011, 02:34 PM   #2
DonDar
DonDar's Avatar
Default
What I did is run the wiring from the lights into the headlight bucket. I put a relay inside the bucket and tapped into the high beam wire for power, that way the lights are always on with the high beams. You can tap into the low beam if you want them on with only that, or the running lights if you want them on all the time. If you want to be able to switch them on and off when you want, you'll need to install a separate switch. Here's a basic diagram of wiring with a relay:
It's actually pretty simple to do, took me less than an hour and only 2 beers.
__________________
2002 V-Star 1100 Silverado
DonDar is offline   Reply With Quote
Old 05-18-2011, 05:00 PM   #3
SkatKat
SkatKat's Avatar
Default
Thanks !
__________________
D & D
Old 05-19-2011, 01:44 AM   #4
mole2
mole2's Avatar
Default
My passing lamps run off of the low beam wire in the headlight bucket. Understand something. The bike was set up to run the OEM passing lights. The wiring for the headlight has a 15 amp fuse yet the headlamp at most uses 5 amps (high beam). Remember, the passing lamps are supposed to be run off of the low beam. There is a 10 amp fues in the OEM passing lights which technically brings us to 15 amps but that isn't happening. My lamps are 55 watts H4 so that's 5 amps x 2. Total draw should be 15 amps for both the headlamp and the passing lights but you're not going to see that because they are actually 4.5 amps at 55 W which makes for 13.5 amps. There should be no problem with direct wiring. IF you experience blow fuses then move to a relay. I have not seen a need for it yet.
Some time in the future I am going to rewire with diodes so the passing lamps run on both the high and low beams. This is not according to DOT regulations but I want the visibility. At that point I may wire in a relay.
__________________
2009 V-Star 650 Classic Pearl White
2007 Suzuki GZ250 Black (sold)
mole2 is offline   Reply With Quote
Old 05-19-2011, 07:36 AM   #5
stargazer
stargazer's Avatar
Default
I just changed mine from running on both low and hi to a weather resistant switch which I located on the left neck of the bike(tight fit). I'm still tied into the elec in the main headlight. Now I can switch them on or off as I please. I have a few extra electrical goodies(aux pwr charger, heated vests x2) that I didn't want to tax the already low reservoir.
Food for thought.
__________________
Ride Safe
Mark
1992 Virago 750
2009 vstar 1100 classic
stargazer is offline   Reply With Quote
Old 05-19-2011, 08:39 AM   #6
SkatKat
SkatKat's Avatar
Default
Thanks for all the info gang. What is the color of wire for the low beam in the headlight bucket? THX . Hope to tackle this weekend
__________________
D & D
Old 05-19-2011, 09:21 AM   #7
stargazer
stargazer's Avatar
Default
Yellow is hi. Green is low and blue is running. Try the following link for good info.
www.sloneservices.com
__________________
Ride Safe
Mark
1992 Virago 750
Old 05-19-2011, 11:39 AM   #8
DonDar
DonDar's Avatar
Default
Mine aren't traditional "passing" lights, and I have them wired to the high beam because I want maximum visibility during the day and maximum vision at night. I always ride with the high beam on unless it's dark and there's oncoming traffic or traffic in front of me. They really increase my vision at night and made a big difference in spotting all the deer we saw last night.
I originally didn't have a relay and had no problems, but over the winter I installed a run-turn-brake kit. With the addition of the rear signals illuminated all the time as running and brake lights, it was a little too much draw on the fuse. I installed the relay and haven't had a problem since.
__________________
Old 05-19-2011, 06:09 PM   #9
stargazer
stargazer's Avatar
Default
Hey Don
Isn't that circuit already on a relay? Why put another relay in the head light bucket?
__________________
Ride Safe
Mark
1992 Virago 750
Old 05-20-2011, 08:43 AM   #10
DonDar
DonDar's Avatar
Default
Originally Posted by stargazer View Post
Hey Don
By using a relay, the lights are being powered directly from the battery rather than from the headlight circuit, which would draw more amperage on that circuit. The relay acts as a switch, and with it tapped into the headlight circuit, the power for the relay itself comes when that particular circuit (high beam, low beam, whichever you use) is activated, switching the lights on. The relay requires very little power to switch it on, so this way you're not overloading the headlight circuit. I hope that makes sense.
I put the relay inside the bucket because 1. it's convenient, since that's where the headlight wiring is, 2. there's plenty of room in there, and 3. it's protected from the weather.
__________________
Forum Jump
1199 Panigale Forum Honda Africa Twin Forum Roadglide Forum Honda CBR1000 Forum Vulcan Forum Yamaha R1 Forum Yamaha R3 Forum
BMW Scrambler Forum Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
