Headlight mod? - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
» Insurance
» Sponsors
» Our Partners
»ATV Reviews
»Motorcycle Games
Go Back   Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum > Motorcycle Models > V Star
Thread Tools Display Modes
Old 11-19-2011, 09:21 PM   #1
la madrugada
la madrugada's Avatar
Default Headlight mod?
I was coming home in the dark and rain and found that the stock headlight was not doing the job. Can I upgrade to a XENON type light? They are very popular in Mexico for cars but have never seen a bike with one. They are and extremly white light that might help in th rain and dark.
__________________
My feet on the pegs and lots of time to go where the road leads.
la madrugada is offline   Reply With Quote
Old 11-19-2011, 10:12 PM   #2
linerdave
linerdave's Avatar
Default Some thoughts
I see people talking about the Slyvania Silvestar bulbs. I tried them years ago when they first came out, wasn't really impressed. I see other say they are a big improvement.
I adjusted my low beam so the top of the spot was just about to come off the ground. To get it out as far as I could with out being in peoples eyes. Then installed passing lamps. The two thirty Watt bulbs made me just about equal to a car's two head lights. I adjusted the passing lamps to be maybe a little higher than the low beams but not as high as the high beam. The passing lamps also light up the side of the road a little better.
linerdave is online now   Reply With Quote
Old 11-19-2011, 11:22 PM   #3
ridgwayrescue
Default
+1 for Passing Lamps. The best money I spent on my bike. Also dresses it up quite a bit. I bought the Yamaha brand and bar too.
ridgwayrescue is offline   Reply With Quote
Old 11-21-2011, 06:33 AM   #4
bevo1981
Default
you can use whatever bulb you want as long as the wattage is the same. you don't have to go with xenon to get brighter light. i have a PIAA halogen Xtreme white bulb. the first mod i ever did on my bike. it made a big difference. a lot brighter than stock. i highly recommend it, or any of the PIAA replacement bulbs.
bevo1981 is online now   Reply With Quote
Old 11-21-2011, 11:03 PM   #5
BP03
Default
Pass on the silverstars, they suck. I got a set for my bike, like an idiot, and regret it again. I always bought them for my cars, because I thought HIDs were too complicated to install.......Well they really arn't lol.
The only reason im not running an HID set up on my bike is because Im not too familiar with the wiring yet...That will be another winter project, lol
__________________
2013 H-D FXS Blackline
2006 V-Star 1100 Classic
alot of things
0331 USMCR
BP03 is offline   Reply With Quote
Old 11-22-2011, 08:36 AM   #6
stargazer
stargazer's Avatar
Default
Take a look at Kuryakyn's 7" Diamond Cut Ice lens. They have 3 different cuts. You still run your OEM bulb but it reflects the light much better. About $60. Great reviews.
I'm hoping Mrs. Clause will be good to me.
__________________
Ride Safe
Mark
1992 Virago 750
2009 vstar 1100 classic
stargazer is offline   Reply With Quote
Old 11-22-2011, 05:24 PM   #7
la madrugada
Default
AS always you guys have given me lots of good info. I will let you know what I am going to do. The rainy season is really gone now and I donīt ride at night because of the lighting. I will choose some method to mod the bike and then get pics and all on the foum.
Thanks everyone.
__________________
Old 11-24-2011, 06:57 PM   #8
mikes99ss
mikes99ss's Avatar
Default
I put this on almost every motorcycle i have ever owned. 55 watt low beam is stock wattage so going through town/passing is stock but when you go to high beam your not much shy of double the power. I also have passing lamps and i have those set of to come on with the highbeams and put 55 watt bulbs in them. When i flip the switch it's 210 watts of power. More than tripple stock light bulb and i still within the output of the generator safely. My dealer said stock generator output at cruising speeds is 275 watts
http://www.ebay.com/itm/Hella-H83140...item5ae39e05d2
mikes99ss is offline   Reply With Quote
Old 11-24-2011, 09:01 PM   #9
linerdave
linerdave's Avatar
Default Heat
I bought a higher power bulb a few years back when I had a V Star. I was afraid the heat would damage the light so I never installed it. There's a lot of heat in a 100 Watt bulb. Heck there's a lot of heat from a 55 Watt bulb. I went with passing lamps instead.
Old 11-26-2011, 12:22 AM   #10
mole2
mole2's Avatar
Default
Federal DOT requires that road/fog lamps go OFF when high beams come on. That's why when you have the additional lighting from the factory they only come on with the low beams (cars, trucks & motorcycles).
As for your 210 watts of power being within the 275 watt output of the charging system my question is what about all the other accessories that are on such as the tail/running lights, stop light, speedometer light, engine running requirements, etc? Just adding passing lamps will put you at or near border line with the charging system without adding additional load. Installing LED lamps in all the other positions can give you more leeway but when using the directionals the load balancers (resisters) will kick in making the usage the same as incadescent bulbs. Not to mention the heat generated within the headlight housing and the probably undersized wiring. Just sayin.
__________________
2009 V-Star 650 Classic Pearl White
2007 Suzuki GZ250 Black (sold)
mole2 is offline   Reply With Quote
Forum Jump
1199 Panigale Forum Honda Africa Twin Forum Roadglide Forum Honda CBR1000 Forum Vulcan Forum Yamaha R1 Forum Yamaha R3 Forum
BMW Scrambler Forum Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
