v-star 1100 high idle untill complete stop - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
» Insurance
» Sponsors
» Our Partners
»ATV Reviews
»Motorcycle Games
Go Back   Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum > Motorcycle Models > V Star
Thread Tools Display Modes
Old 05-18-2012, 06:49 PM   #1
stretchman
Default v-star 1100 high idle untill complete stop
OK first post on this forum. I got a 2000 v-star 1100 classic, very high idle while driving till I come to a complete stop, then it goes down to normal set idle after a few seconds. Ive seen this problem with my searches but haven't found solution. This will happen even if I jack the rear tire off ground, blip throttle and returns right to set idle, if I rotate the rear tire and blip the throttle it will stay high until I stop the tire. It is NOT the cables/choke sticking. If I unplug the speedo sender unit it goes away and operates correctly. I have purchased used parts and installed both the speedo censer and the cdi box thinking it was one of them having issues, (one of the wires are connected from senser to cdi) to no avail. I do not see how this could be a vacuum leak or exhaust leak, or jets clogged up. Any help or ideas will be appreciated, locale repair shop has no idea how these symptoms are related
stretchman is offline   Reply With Quote
Old 05-19-2012, 04:47 AM   #2
dave star
dave star's Avatar
Default
stretchman this is from a clymer book,incorrect carb synchronization or stuck chock valve or idle adjust screw incorrectly set
__________________
07 v star 1100 Sliverado-chrome accessories-switch covers-master cylinder cover-fender tips-horn cover-headlight viser-skull levers. Trunk-extra break an running lights-Micks ssd kit-bikers choice tach-dwg speakers-chubby kit-lightbar--cobra pipes an crashbar-mustang set
dave star is offline   Reply With Quote
Old 05-19-2012, 08:22 AM   #3
stretchman
Default
Dave all those things would not be able to detect movement of the rear tire, if I'm just sitting there and blip the throttle it will return to set idle every time. If I push the bike even backwards and blip the throttle it stays around 1500-2000 rpm untill I come to a complete stop (not before) then it will drop down to set idle (a few seconds after complete stop). I can keep it rolling backwards with my feet and it will not come down to idle, untill dead stop then it returns to idle. Its crazy and dosnt make any sense to me. I also have sinked the carbs with my home made tube/oil gauge
Old 05-19-2012, 03:22 PM   #4
Sick Mick
Sick Mick's Avatar
Default
Have you checked or adjusted the TPS?
__________________
Sick Mick* 2006 V Star 1100 Custom - Custom striping, lettering and paint by Sick Mick – 6* Tree – 21" front wheel - Hard Krome Sideburners - Progressive suspension – Adjure lens in Fat Boy housing – 16” stainless steel apes, switches relocated - Single throttle control – “Silent” pods – Sick Mick Solenoid Delete - Custom Spring seat - A piece of my soul.
The fuel tank is still stock though..... for now
The V Star 1100 wKB - https://sites.google.com/site/vstar1100kb/home
Sick Mick is online now   Reply With Quote
Old 05-19-2012, 05:26 PM   #5
stretchman
Default
I did but it was a while ago I will check that again Thanks for the reply, sick!
Old 05-20-2012, 06:21 PM   #6
notfried
Default
my '01 did that when I first got it. It ended up being a float sticking.
notfried is offline   Reply With Quote
Old 05-20-2012, 06:49 PM   #7
stretchman
Default
Notfried can you explain your exact problems And float sticking like not letting fuel in or letting to much fuel in?
Old 05-21-2012, 06:30 PM   #8
notfried
Default
Mine was like it was letting too much fuel in. My floats weren't "floating"...or moving. They were stuck "up", instead of moving up and down, they were frozen. I would fire it up and let it warm up, then when I move the idle would be high until a couple seconds after I fully stopped. If I slowly rolled through a stop sign, it'd idle high or race, but if I came to complete stop it'd settle. And when creeping through my sub-devision it'd be high until fully stopped. Like it'd settle after the fuel quit "sloshing" around, or that's how it seemed. I freed up the floats and re-adjusted them and haven't had that problem since.
Old 05-21-2012, 08:10 PM   #9
stretchman
Default
Problem has been resolved, not sure what i did, well lots cleaned all connections, adjusted tps again that might have been 1/2 the problem, had to turn it all the way clockwise and remove a washer I had one it to get it to rotate far enough. Ohms were at 850 or so and book calls for no more than 840k. Thanks for all the input, Brad
Forum Jump
1199 Panigale Forum Honda Africa Twin Forum Roadglide Forum Honda CBR1000 Forum Vulcan Forum Yamaha R1 Forum Yamaha R3 Forum
BMW Scrambler Forum Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
