2003 1100 custom starting problems - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
» Insurance
» Sponsors
» Our Partners
»ATV Reviews
»Motorcycle Games
Go Back   Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum > Motorcycle Models > V Star
Thread Tools Display Modes
Old 05-30-2012, 09:43 PM   #1
fah_kinright
Unhappy 2003 1100 custom starting problems
V-star 1100 custom has a start problem.... i think
can anyone tell me what's going on with my bike. is it just the starter. i bought it like this, but after adding a new battery it went away. now it's back.
sometimes if will do this over and over again. so i stop after maybe 4 tries, and then do it again. the other night it would not go.
please watch the short video.
fah_kinright is offline   Reply With Quote
Old 05-30-2012, 09:55 PM   #2
aide
aide's Avatar
Default
Here is a link to look at and I am sure many other will jump in.
http://www.sloneservices.com/SilverB...08.htm#Starter
aide is offline   Reply With Quote
Old 05-30-2012, 10:53 PM   #3
Sick Mick
Sick Mick's Avatar
Default
What does the battery voltage drop to when you crank the starter?
Have you check the reg/rec to see if it's charging? Also, have the battery load tested.
__________________
Sick Mick* 2006 V Star 1100 Custom - Custom striping and paint by Sick Mick – PCS 6* Tree – 21" front wheel - Hard Krome Sideburners - Progressive suspension – Adjure lens in Fatboy housing – 16” one off stainless steel apes - Single throttle control – “Silent” pods – Sick Mick Solenoid Delete - Hand built spring seat - Kury 9252 plate mount ...
The fuel tank is still stock though.....
The V Star 1100 wKB - https://sites.google.com/site/vstar1100kb/home
Sick Mick is online now   Reply With Quote
Old 05-31-2012, 04:31 AM   #4
Rickt
Default
I have the same problem with my 04, the dreaded starter clutch. right now I am going as long as I can before fixing it. mine has been doing it for 6 months. dont give it any gas or choke from the start. once it catches give it gas and engage choke if needed.
__________________
2004 1100 silverado
Rickt is offline   Reply With Quote
Old 05-31-2012, 04:04 PM   #5
fah_kinright
Default
had the battery tested by the vendor and it's coming back perfect.
what would be the reg/rec?
Old 05-31-2012, 04:05 PM   #6
fah_kinright
Default
how do you know how long it can go?
how do i know it it's just the starter or the starter clutch
Old 05-31-2012, 04:18 PM   #7
Sick Mick
Sick Mick's Avatar
Default
BTW...what is your idle set at? It sounds really low.... should be 950-1000 for proper oiling at idle.
So the battery checks out fine and doesn't lose any charge while in the bike? The reg/rec is like a voltage regulator. if it goes bad, you either over or under charge.
I'd remove the starter too. Look at the 2 long bolts holding it together to make sure they aren't twisted. If they are loosen them and twist everything back where it should be.
__________________
Forum Jump
1199 Panigale Forum Roadglide Forum Honda CBR1000 Forum Vulcan Forum Yamaha R1 Forum Yamaha R3 Forum
Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
