How long should engine run rough at first start? - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
» Insurance
» Sponsors
» Our Partners
»ATV Reviews
»Motorcycle Games
Go Back   Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum > General StarBikeForums Discussions > General Bike Talk
Thread Tools Display Modes
Old 11-01-2012, 06:15 PM   #1
Clear_Lake_VStar
Clear_Lake_VStar's Avatar
Default How long should engine run rough at first start?
I have an '09 VStar 650 with about 1600 miles on it. I rode it last Wed and then again today. We have had a few "cool" mornings in the Houston area leading up to my ride today. It definitely needed to start with the choke on this morning. I ran it with the choke for about 30 seconds and the engine quit shortly afterwards. I ran it with the choke a little longer but it quit again at low idle speed. After running it a while without the choke at higher RPMs it finally responded like I wanted it to before taking it to the streets.
Is this first start/run performance after a week of not riding normal? How high of an RPM setting should I run after initial start-up and choke in?
I am pushing my next gas fill-up to get more data on my MPG average, so I should have had at least 1 gallon of gas left in the tank if not at least 2 gallons. Houston humidity a factor today? (it was foggy for my ride).
I would like to try adding some StarTron or Stabil gas treatment. Which one would you recommend? Either is OK?
Looking forward to some helpful responses.
Thanks.
__________________
2009 Yamaha VStar 650 Silverado
Clear_Lake_VStar is offline   Reply With Quote
Old 11-02-2012, 04:59 AM   #2
stratowart
Banned
Default
I, as do many other members, will use Sea Foam as a fuel additive. Use as instructed after you fill up the tank next.
However, an '09 with only 1600 on the odometer tells me that this bike you have sat for long periods of time with aged gas in the tank and fuel lines. It may take a few more tanks of treated gas to help, IF at all.
stratowart is offline   Reply With Quote
Old 11-02-2012, 07:17 AM   #3
Tadelk
Tadelk's Avatar
Default
One thing I have noticed with my new v star 650 is when the weather is cooler, I have to turn the idle speed up a little and when it's warmer and humid, I have to turn it down. I don't have a rpm gauge on my bike. I just listen to the engine. Try turning the idle up some and see how that works out for you.
I do use my choke as well. I run full choke for about 7 sec then half choke for about 30 sec while letting it idle which gives me time to put my gear on and get my mind set on the ride.
Sent from my iPhone using Motorcycle.com Free App
__________________
Thanks,
Todd
2011 Yamaha V-Star Custom 650 ( XVS650AB )
Southern Cruisers Chapter 017 (Southwest Al.)
Tadelk is offline   Reply With Quote
Old 11-02-2012, 10:22 AM   #4
the8thst
the8thst's Avatar
Default
That sounds a lot quicker to start cold than mine. Temp range of 40-45 requires full choke for 3-5 minutes, then 1/2 choke for a few minutes of idling, and finally 1/2 choke for a few blocks of riding.
It normally doesn't stay running the first 1-3 times it turns over. I have to start it - let it stall - wait a few seconds - start again, etc.
the8thst is offline   Reply With Quote
Old 11-02-2012, 11:17 AM   #5
Clear_Lake_VStar
Default
Thanks for the responses. I rode my VStar again today and the start performance was better. After about 30 seconds of full choke I kept the RPMs up for about 45 seconds and the throttle performance was good afterwards. Running it yesterday and keeping the RPMs up I think did the trick.
It is good to know that:
1) You can use idle speed adjustments if you have to for hot or cold weather riding
2) You can use SeaFoam as a fuel additive (Should I have any concerns of this being too strong compared to using StarTron or Stabil as a first treatment method for my VStar?)
and 3) Other riders use the choke for extended periods of time for cold weather start-ups and initial riding.
__________________
Old 11-02-2012, 01:07 PM   #6
Postmaster
Postmaster's Avatar
Default
+1 on the Sea Foam. I've used it in all my bikes from the get-go and never had a problem, even with carburated bikes. I get it at Wally Mart for a reasonable price.
__________________
Jeff
BLUE BIKE CLUB
2012 V-Star 950T-Impact Blue
Kuryakyn ISO grips
Back-Off taillight modulator
OEM passing lights
OEM luggage rack
OEM engine guards, saddlebag guards and trim rails
Clevver clutch lever
Formotion gauges
Show Chrome Headlight & Passing Light visors
Mustang 2 piece wide touring seat with backrest/studs
Postmaster is offline   Reply With Quote
Old 11-02-2012, 02:34 PM   #7
Tadelk
Tadelk's Avatar
Default
How often do you use sea foam on carb bikes? Mine has duel carbs.
__________________
Thanks,
Todd
Old 11-02-2012, 04:28 PM   #8
arjeepguy501
Default
The best response I can give you is to read your owners manual. It will tell you how to properly use the choke to start the bike. I think it is something like this. Full choke for about 30 seconds or so then half choke for several minutes if really cold. the way to tell if properly warmed up and ready to ride, close choke, idle should smooth out, goose the throttle if it responds immediately, as it should, the bike is good to go.
__________________
2009 V Star 650 Classic
Debadged, Scootmods 4in. Forward Control Extensions, Mustang Rear Fender Bib (when SOLO), Vance & Hines Cruzers, Barons BAK Stealth, Back Off Brake Light Modulator, Barons A.I.S. Removal Kit, Yamaha OEM light bar and driving lights, River Road Saddle Bags, AirHawk 2, Homemade floorboard kick out pegs, Grasshopper Backrest, Yamaha Tall Sissy Bar, 14 inch Kong Bars (internally wired), Stainless lines and cables, Avon Grips.
More to Come
arjeepguy501 is offline   Reply With Quote
Old 11-02-2012, 04:35 PM   #9
Postmaster
Postmaster's Avatar
Default
Some I know use it at every fillup. I use it about once a month to keep things clean.
__________________
Jeff
BLUE BIKE CLUB
Kuryakyn ISO grips
OEM passing lights
OEM luggage rack
Formotion gauges
Old 11-03-2012, 09:46 AM   #10
Miescha
Miescha's Avatar
Default
My 2006 1100 had 4000 miles when I got it in August. It sat for a long while before I got it according to the person storing it and the inch of dust on the bike. It would run without the choke at 3/8 or better. Three tanks of seafoam helped but wasn't fixed until I removed and cleaned the carbs. Then it started without choke at all and ran great until about a week or two ago when the temps dropped into the 30s and 40s in the mornings with highs of 60 at best. Now it needs half choke to start and I leave it there while I get my gear on - so a few minutes at most. As I pull out of the drive I move the choke completely off - I get throttle hesitation if I don't do so quickly.
But I've also got 21.5 pilot jets rather than the stock 17 jets so its getting more fuel at idle to start with.
__________________
2007 Stratoliner 1900 S
2006 V Star 1100 Classic
Miescha is offline   Reply With Quote
Forum Jump
1199 Panigale Forum Honda Africa Twin Forum Roadglide Forum Honda CBR1000 Forum Vulcan Forum Yamaha R1 Forum Yamaha R3 Forum
BMW Scrambler Forum Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
