99 vstar battery question - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
post #1 of 3 (permalink) Old 07-20-2018, 08:32 AM Thread Starter
Cameron Burns's Avatar
I have a 99 vstar 1100. The battery is showing a full charge. The connections are tight. Sometimes it just won’t start after sitting. It will crank, then just clicks. Any ideas? Is the battery just shot? I did let it run down once but have had it on a charger multiple times. It’s work like a champ til it sits then does it. The battery still shows 12-13
Cameron Burns is offline
post #2 of 3 (permalink) Old 07-20-2018, 08:47 AM
How long before starts is it sitting? A load test is the best way to determine the condition of a battery. Any auto parts store can complete load test. Also check the negative cable to frame connection, sometimes it will loosen or has corrosion.
Les B.
post #3 of 3 (permalink) Old 07-20-2018, 08:51 AM
If you have a meter here is a simple home test.
Les B.
