tps sensor - Page 2 - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
 8Likes
post #11 of 20 (permalink) Old 08-06-2019, 07:18 PM
The only conclusion I can make is the TPS sensors are bad. Seems like you are doing everything right. With low resistance it would reduce the amount of timing thus reducing horsepower a bit.
post #12 of 20 (permalink) Old 08-06-2019, 07:28 PM Thread Starter
i have a 25 watt 10 ohm resistor, on the 20k setting i get 0.80. on the 200k setting 7.5
nick57 is online now
post #13 of 20 (permalink) Old 08-06-2019, 07:34 PM
Do you access to another meter for a double check?
Deeksvstarclassic likes this.
post #14 of 20 (permalink) Old 08-06-2019, 07:41 PM Thread Starter
post #15 of 20 (permalink) Old 08-06-2019, 08:45 PM
blackadder's Avatar
Originally Posted by Redbird58 View Post
Completely off subject but Lumberg needs you to come in on Saturday to do those TPS reports....Yeh that would be great...
Sorry it's been that kind of day! Now back the subject at hand....sorry for the detour!
EVERY time I see the letters 'TPS'.
Redbird58 likes this.
blackadder is online now
post #16 of 20 (permalink) Old 08-06-2019, 09:00 PM
Were you doing this as a maintenance item of were you having issues? Saw where you posted on the Vstar facebook page. Hopefully Tim or Mick will chime in.
post #17 of 20 (permalink) Old 08-06-2019, 10:30 PM
if the meter only goes down to 20K ohms for the lowest range, then 1 k ohm is 5% of full scale
if the meter is really accurate, say 1%, then your error band is+/- 200 ohms
the 10 ohm resistor is .05% of full scale, the meter would never be that accurate - that is down in the noise floor.
To check the meter you will need a 1% 10k or 5k ohm resistor.
a meter with a 2K ohm range would be better suited
post #18 of 20 (permalink) Old 08-07-2019, 05:03 AM Thread Starter
i thought i was getting a clunk on shutdown and maybe the horsepower a little low....mick &tim have not responded, maybe the readings don't make sense to them. i'm going to get another meter, i paid $30.00 for this one at lowes...kcw its a 5% resister and at 2k i get .221.at set at 200 i get 100.2
post #19 of 20 (permalink) Old 08-07-2019, 09:18 AM
Not now, Redbird...I gotta meeting with the Bobs.
Cliffieg is offline
post #20 of 20 (permalink) Old 08-07-2019, 11:18 AM
Redbird58's Avatar
So @Cliffieg what is it exactly that you do here? We should start a thread about best movie lines.
09 V Star 950
Be seen and be heard! Bright lights and loud pipes!
Enjoy the ride
Redbird58 is offline
