More and more companies have become certified as top tier fuel suppliers so there is no excuse not to use top tier fuel anymore.
Top-tier gas is not the highest number on the fuel pump, but rather it is gas manipulated with additives and detergents to help your engine run more smoothly.
What Is Top-Tier Gas?
Most people tend to look at fuel prices first when they choose a gas station for a fill-up. Or drivers simply go to the station that's most convenient at the time. However, some automakers and plenty of experts recommend filling at stations that sell top-tier gas.
It's commonly believed that all brands of gas are more or less the same. This is partially true. All gas is refined in the same way and it comes from crude oil. Gas in the U.S. is required to include certain additives to keep engines clean.
However, the top-tier gas brands do more than just the minimum requirements set by the EPA. Top-tier gas meets the more stringent standards set by some of the top automakers. It's a trademarked name that is derived from a program started in 2004. It was then that several automakers were concerned that EPA standards weren't strong enough to protect their new high-tech engines. Top-tier gas uses a number of approved additives to reduce engine deposits and sticky valves.
What stations can you purchase top tier fuel from:
How To Recognize Top Tier Gas Stations
There are a large number of well-known gas retailers that sell top-tier gas, including over 50 brands. You can recognize individual stations that sell top-tier fuel by the trademarked logo. A list of brands selling top tier fuel includes:
76
Aloha Petroleum
Amoco
ARCO
Beacon
BP
Break Time
Cenex
Chevron
CITGO
Conoco
Co-op
Costco
CountryMark
Diamond Shamrock
Entec
Esso
Express
Exxon
Holiday
Kwik Star Stores
Kwik Trip
Mahalo
MFA,
Mobil
Ohana Fuels
Petro-Canada
Phillips 66
PUMA
QT
Quik Trip
Road Ranger
Shamrock
Shell / Shell V-Power
Sinclair Standard
SuperAmerica
SuperFuels
Tempo
Texaco
Tri-Par
Valero
Remember that using top-tier gas has nothing to do with the octane ratings. If a station sells top-tier gas, then all of its gas grades should be top-tier quality.
https://www.autolist.com/guides/top-tier-gas
Remember that more companies are becoming top tier so check lists, here is another list with some additional companies added to it.
https://clark.com/cars/top-tier-gas-stations-clean-engine-aaa/
They also show a comparison of valves using non top tier fuel and top tier fuel vs a new valve, if that does not convince you to use top tier fuel then there is no converting you.
76
Aloha Petroleum
Amoco
ARCO
Beacon
BP
Break Time
Cenex
Chevron
CITGO
Conoco
Co-op
Costco
CountryMark
Diamond Shamrock
Entec
Esso
Express
Exxon
Holiday
Kwik Star Stores
Kwik Trip
Mahalo
MFA,
Mobil
Ohana Fuels
Petro-Canada
Phillips 66
PUMA
QT
Quik Trip
Road Ranger
Shamrock
Sinclair Standard
SuperAmerica
SuperFuels
Tempo
Texaco
Tri-Par
Valero
