Belt Drive Tension - Page 2 - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
 9Likes
post #11 of 15 (permalink) Old 07-14-2019, 11:45 AM
GreenMtnHunter's Avatar
First thing I noticed was that the belt on my SVTC seems a bit narrower (1/8th inch)than the one on my Road Star and Warrior. Outside of abuse, I don't know (personally) of anyone who has changed out a Yamaha belt unless it was at that point of service, and just because the book said to do it.... My SVTC hum comes in briefly at lower speeds, coasting or engine breaking; I have assumed it is tires or the belt...hoping it's not the tranny... The Metzlers on my RS have terrible whine at corners, so I was hoping that was tire noise. I am also decently hard of hearing in the higher ranges so I don't hear it much, or my best riding partner whenever she has important instructions...
I can't wait to see what you all figure out; going out to check the belt tension now....but riding partner want the the quad and trailer backed into a narrow spot along a fence...
Rich
Seven Stars/Tuning Forks
2018 SVTC
GreenMtnHunter is offline
post #12 of 15 (permalink) Old 07-15-2019, 07:45 AM
ChiefGunner's Avatar
Originally Posted by Bucfan11 View Post
Originally Posted by RonK View Post
I just got back from a 9,000 mile trip. Bike now has 22,000 miles. For the entire life of the bike I have heard a kind of squeal. I used to think it was the front rotor as my Road Star was noisy there. Then I thought maybe something in the engine, but varying the engine speed doesn't change the sound. It's not always constant or the same loudness. I thought maybe some bearings were dry as it kind of sounds like that kind of hollow squeal. I now suspect it's the belt although it isn't so constant I can make it happen at any given speed, although at high speeds you can't hear that well.
Has anyone changed the tension of their belt yet to see if that quiets down any noise?
I have...made a tremendous difference. I loosened mine to the max of 7mm travel and it is a lot quieter. I still hear it but it is better. This is one of the things I think Yamaha missed on. It should be shaft drive. I have 21k on mine and loosened it at 14k, should have done it at the dealership when I picked it up.
I had a howl or growl on mine at certain speeds. The belt tendon was set at the middle to upper manual specs. I found that when I loosened it to the lower end of the specs that the noise went away.
ChiefGunner is online now
post #13 of 15 (permalink) Old 07-15-2019, 09:11 AM
RonK's Avatar
Location: Western Colorado (Grand Junction) summers, Wickenburg, AZ winters.
Originally Posted by sdunker View Post
I was getting a loud howl at certain speeds. I checked belt with rear tire off the ground. The tightest spot had only 3mm of slack. Yamaha says 5-7mm of slack at tightest point. I played with the belt slack for a couple of days and ended up at 10mm of slack at tightest spot. I also found out that the marks on the side of the swingarm arn't exactly perfect. My belt would run to the outside of both the front and rear pulley and I knew this wasn't correct. I took cowpuc's advise and spun tire and adjusted till belt was running in center. When I got done it makes very little noise, I think all I hear now is tire noise.
Is it necessary to take bags off, muffler off, and caliper to get to where you can loosen the axle nuts? On my Road Star the tension was always done by using the "half twist" method which seemed to work okay. Are you using a tension tool?
How will I know when I get there if I don't know where I'm going?
RonK is offline
post #14 of 15 (permalink) Old 07-15-2019, 05:26 PM Thread Starter
Bucfan11's Avatar
You do not have to take the caliper off to adjust belt.
Rob - 18 Raspberry SVTC, 08 Pearl White Navi Goldwing
Bucfan11 is online now
post #15 of 15 (permalink) Old 07-24-2019, 03:47 PM
This morning I relieved a little tension on the belt - from maybe a quarter to half a bar of movement in the window at the guard, to almost a full section of a bar in that same little window. The difference is dramatic! Up until today, I have had a loud whine at 25-45 mph in 3rd and 4th, probably limited by my poor hearing...I knew it was the belt because the clutch and engine rev's did not seem to be related. After the adjustment, I heard just a note of whine ONLY when I dove into a hard right hand corner. I did not spin the wheel, but did the adjustment with the bike on the ground. Aligning the rotation might ;-) be a good idea, as well.
My Yamaha service tech said, "Yeah, I probably should have done that; it was at the minimum of the spec when you picked it up...As long as you're not into Jack-rabbit, cowboy,(?) hole-shots, you could probably go just a bit softer...."
I did not remove the bags or the pipes, though it would have helped... A little, actually, about a foot and a half, of leverage on a 12-14" wrench sure helped though.
Rich
2018 SVTC
08 and up raider rear belt pully and belt Strat One Wanted Items 3 05-24-2014 09:00 PM
Belt tension changes? rmccutchan V Star 2 06-16-2013 10:41 PM
Belt tension on 1600 Roadstar Arty Road Star 6 12-09-2012 10:08 PM
1300 Belt Tension rmccutchan V Star 0 07-13-2012 11:25 PM
belt tension for stratoliner deluxe mark31277 Stratoliner & Roadliner 4 09-24-2010 10:30 PM
