07 RSTD carb jet kit - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
post #1 of 3 (permalink) Old 08-01-2013, 10:01 PM Thread Starter
I was wondering if someone could direct me to a company that makes carb jet kits for the later model Royal Stars. Everywhere I look they are only for the 96-01 models, and I understand the carbs are somewhat different on the later models. I've got K&N air filters in the stock airboxes, and recently installed some Python 3 1/2" slip on mufflers that I had saved from one of my Harleys.
It does have a bit of a hiccup when the engine's not warmed up but runs pretty good after that....I just figured I might be able to get a little more giddy-up if I did a little carb adjusting. By the way, with the Pythons on it it sounds great! I put in the optional "quiet" baffles and wrapped them with fiberglass packing.
Any help would be appreciated.
Mildbill52 is offline
post #2 of 3 (permalink) Old 07-22-2014, 03:21 PM
Do a quick plug check before trying any jetting changes so you don't end up chasing your own tail.
tankerman is offline
post #3 of 3 (permalink) Old 12-13-2014, 07:09 AM
I am going to try these http://www.ivansperformanceproducts.com/xvz1300.htm And if tankerman is tankerhank from delphi read what he has tried because apparently it was a labor of love to get it to perform. I'm just starting what he has already done and his work has saved me a lot of work. Many thanks Hank
smlogan is offline
