2006 dash replacement - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
  • 1 Post By Maineman
post #1 of 3 (permalink) Old 08-20-2019, 12:42 PM Thread Starter
Maineman's Avatar
When I bought my bike the center console ( speedo, tack, fuel gauge) had been replaced with a 2009 model.
My select switch and reset switch do not work currently . Everything else seems to work ,i.e. speedo , fuel gauge , tach , clock which I can't adjust .When I took the center console off I noticed that the wiring must be different on the 09 version as I have a couple of plugs that are not compatible .
Questions .............
What is the button for ?
It appears that the plug on the bike has two wires which I assume come from the select/reset switch but the plug on the console has 4 wires .
Can I wire this together to bring my selector switch and reset switch back to life?
https://www.starbikeforums.com/forum...s/confused.gif
Thanks for the help in advance .
ID:	85056   Click image for larger version
ID:	85058   Click image for larger version
ID:	85060   Click image for larger version
Maineman is offline
post #2 of 3 (permalink) Old 08-20-2019, 10:52 PM Thread Starter
Maineman's Avatar
After further investigation I've found where this button shows up beginning in 2009 roadliner and stratoliner .
People that have at least an 09 should be able to tell me what this button does?
See the attachment ................
ID:	85068   Click image for larger version
Maineman is offline
post #3 of 3 (permalink) Old 08-22-2019, 10:13 AM Thread Starter
Maineman's Avatar
Ok,
After locating an owners manual online for a 2009 I've found that the mystery button is a reset button. I guess in 2009 they moved the reset button from the right handle bar to the button on the console . Why, I don't know.
This explains why the plugs are different. After studying the wiring diagrams, I cut the plugs off the wires and connected the wires with bullet connectors so now all my dash functions work .
Yippppeeeeee
Although I still have to deal with the button since my console has no hole for it .
I don't know if this thread will ever help someone else but it helped me.
Maineman is offline
