Here's the Problem - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
 12Likes
post #1 of 12 (permalink) Old 03-03-2016, 08:47 AM Thread Starter
Here's the Problem
There is definitely more stress on the handlebar when it's a trike. I proved it yesterday when I had to do a slow speed left turn in town yesterday. The left side broke free and pulled into my side. Luck was with me as the right side was still rather tight and while going under 35 mph, made the 15 mile trip home. Anyone else ran into this problem? I TIG welded the crack and break together, then primed the center section for painting today. I do believe the combination of addition force needed to turn at low speed and those vibration dampeners allowing the bar to move (does't add any strength between the two risers) allowed leverage to be applied in the center and break. Of course having the hole for the wires and from what I could see, the edges of the holes were not cleaned up, and the handlebar is much thinner than I expected, I understand why it broke. I'll be looking for a replacement handlebar after my ride in April.
bevo1981, bevo1981, Elk and 1 others like this.
Hugh R. Acosta Jr.
Retired Air Force
Stratovarious is offline
post #2 of 12 (permalink) Old 03-03-2016, 10:17 AM
WOW, that's SCARY
2014 Stratoliner S
kc61 is offline
post #3 of 12 (permalink) Old 03-03-2016, 10:59 AM
post #4 of 12 (permalink) Old 03-03-2016, 02:05 PM
sonysnek's Avatar
Wow man, glad yer ok. Coulda been ugly if happened when goin faster. Looks like it had been cracked for some time before letting go. And yeah does look like very thin wall tubing. Most definitely time to replace.
Sonysnek
sonysnek is offline
post #5 of 12 (permalink) Old 03-03-2016, 03:26 PM
that could induce skid marks and not on the asphalt..lol glad your ok.
post #6 of 12 (permalink) Old 03-03-2016, 10:36 PM
Big pucker factor there, glad your safe!
Mental
Mental Floss Tycoon is offline
post #7 of 12 (permalink) Old 03-03-2016, 10:36 PM
I also am glad you are ok, it does look like very thin material.
post #8 of 12 (permalink) Old 03-04-2016, 06:30 AM
Corsair's Avatar
I noticed how thin this was when I installed my Barons pull back risers. Glad you weren't hurt.
Corsair is offline
post #9 of 12 (permalink) Old 03-04-2016, 03:59 PM
rayvin57's Avatar
+1--glad it didn't happen at speed and that you're ok, Strat. I assume the walls of the new bar you'll be searching for next month will be a bit thicker...
'06 Black Cherry Roadliner
rayvin57 is offline
post #10 of 12 (permalink) Old 03-07-2016, 08:41 AM Thread Starter
I will not go with OEM if possible. My plans are to find out what the rise and pullback are for stock bars and then look for ones to match. Before settling on one, I will ask for the metal thickness at the wire exit hole. Of course that is subject to slight change if I can get an OEM bar for cheap/free. I can then run a TIG bead around the wire hole to reinforcement.
But when it happened I was actually more surprised than scared at first. Though while headed home the right bar was getting looser as the miles went by.
Anyone want me to post pic's of the "skid marks"? Might need a WIDE angle lens...
Hugh R. Acosta Jr.
Retired Air Force
