Need advice!... - Page 3 - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
 6Likes
post #21 of 29 (permalink) Old 10-01-2018, 10:41 PM
Highwayman's Avatar
National Cycle Chopped. You can use the mounting hardware with the shorty, chopped or full size windshield. The shield comes off very easily without tools.
ID:	82440   Click image for larger version
ID:	82442   Click image for larger version
For mad scientists who keep brains in jars, here’s a tip: why not add a slice of lemon to each jar, for freshness?
Highwayman is offline
post #22 of 29 (permalink) Old 10-02-2018, 04:37 AM
If you want to maintain the classic HD bagger/cruiser look then a tombstone shaped windshield is the common way to go. There are selection guides on websites like Revzilla and Bikebandit.
If you go that route you can just get a big one, that is a little taller than your eye level, and that will knock the air out of your way. The drawback is you have to look thru the plastic, and when its raining or covered with dirt and bugs it will be hard to see. It will also load up your engine noticeably and put a big drop on your mpgs.
The other approach is to get one that is about as high as your nose. You look over the top and it throws the air up over the top of your helmet. At highway speeds (70mph or more) these can be difficult to set up just right, and you may need fork deflectors or "lowers" to get the air to flow up and over your helmet so you dont get any head buffeting.
Head buffeting is not just air hitting your helmet. When you ride with no windshield you get a nice steady flow of air over you and your helmet. The faster you go the force increase by the square of your speed, but it is always steady air (unless you get behind a truck). When you put a windshield on your bike the flow is smooth off the edge of it, but some distance back it breaks up and becomes turbulent and chaotic. If that turbulent air hits your helmet its like your head is in a paint can shaker - your eyes wiggle so much your vision blurs and your brain is being vibrated in your skull. You will not be able to read road signs, and you will get a terrible headache in a manner of minutes at 75mph. You can NOT ride like that, you are literally getting a mild concussion from your head being shaken like a bowl of jello. You never get this effect riding with no windshield - it is worse than having nothing on your bike. If you slow down to 60mph or less it stops. Again, it can take quite a bit of adjusting the angle of the windshield and the position of the fork deflectors to get an acceptable ride at 80mph with this setup. Not a great ride, just ok.
The other way to go, if you really want to get on the interstate highways and haul, is to put a bat wing or a full fairing (like a Goldwing or Venture) on your bike. It will no longer look like a 1960s HD cruiser, but it will put you in a nice still pocket of air with no head buffeting, and you wont have to play with the exact height of the clear part, or mess around with fork deflectors.
post #23 of 29 (permalink) Old 12-15-2018, 06:10 PM
terpof1's Avatar
Looking for a headlight bullet fairing with mount kit included
terpof1 is offline
post #24 of 29 (permalink) Old 01-03-2019, 08:53 PM
Can you post a pic of what you're looking for? I replaced my stock Raider Headlight with 9" pinch style light. If you use a pinch style light, you'll need a headlight adapter bracket from CustomRider.net.
Pics of my light install.
Name:	Copy of Hdlight1.jpg
bigdaddyl is offline
post #25 of 29 (permalink) Old 01-03-2019, 10:24 PM Thread Starter
Yea, I think a bullet fairing or a cowl would be a best compromise between practicality and aesthetics. It would take the wind off of my chest and still preserve the look of the Raider.
I've found one online that I like and is affordable (see attached photo) but it comes with NO hardware. Anybody installed something similar? What hardware did you use?
Sent from my SM-G950U using Tapatalk
tisunac is offline
post #26 of 29 (permalink) Old 01-04-2019, 06:09 AM
Check out Memphis Shades - comes with hardware
https://memphisshades.com/products/b...-xv1900-raider
post #27 of 29 (permalink) Old 01-04-2019, 06:45 AM Thread Starter
Yea, this one is nice.... I might get a cheap one first and mount it somehow on the bike to try first.... Just to make sure it'll work for me before I spend $320 for a decent one.
Thank you for your suggestion. Appreciate it.
tisunac is offline
post #28 of 29 (permalink) Old 01-04-2019, 07:27 PM
Highwayman's Avatar
Bigdaddy, can you send a link for that air mod you have on your bike? Also did it affect performance aside from looking cool?
post #29 of 29 (permalink) Old 01-09-2019, 06:59 PM
Hey Highway -
The SPIKE mod (Spike Air Cleaner or SAC) done to a Raider is only aesthetic; it's not in anyway functional as an air intake. The SAC does serve as a coil holder for the right side, and mine is wired with red LEDs.
I tried to attach the instructions for the SAC install - file is too big. If you want it I can email it to you...
Some added pointers include:
- use fiber lock nuts
- use blue loctite
- don't overtorque; that area has a lot of thermal expansion and contraction
- be sure to have extra drill bits and use WD40 to cool the bits as they turn
- protect all exposed areas from damage while working
Good luck!
PS: there's another Raider rider with the handle "Highwayman"; think he's from Ohio, and posts on the Roadstarraider forum.
