429 Cams - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
post #1 of 4 (permalink) Old 02-20-2013, 03:27 AM Thread Starter
SThomas's Avatar
429 Cams
Looking at installing SS custom cycle's 429 cams on my vstar 1100. They are recommending that with this mod, I also install a 64lb clutch conversion and a Dyna ignition module.
Question I have is, are these components truly necessary. Combined these will run approx $400 on top of the cams.
SThomas is offline
post #2 of 4 (permalink) Old 03-23-2013, 08:51 AM
SmittySmithsonite's Avatar
Sounds like the cams add some ft.lbs. of torque - that must be why you need the heavier clutch springs. The ignition module will allow you to set the timing where the bike runs best - no way to do that with the stock setup. If it were me, I'd do both, for sure. It'll run that much better. You'd be amazed what a few degrees of timing will do.
'06 Roadliner Midnight - heavily accessorized (SOLD, summer of '14)
SmittySmithsonite is offline
post #3 of 4 (permalink) Old 04-12-2013, 01:54 PM
Fulltilt1's Avatar
You could get a second Diaphram Spring for your existing clutch for about $70 shipped and just double them up.
Mine has 29K on it and I'm starting to see slippage about 2K since cams and pistons.
GW
2005 1100 Custom
Speedster Slashdowns
ORKed 5/16" Lines
PODs K&N RU-600s W/PCV
PCS XXX/2 cams
AIS Removed/Plugged
Pro-1 Tach
TPS Connected
Memphis Shades Bullet Fairing
Progressive 465 rear
Fulltilt1 is offline
post #4 of 4 (permalink) Old 05-28-2013, 09:08 AM
Did you do your cams and pistons yourself or take it to a shop. I am about 80% ready to pull the trigger on this stuff but I want to know the difficulty in install VS how much a shop would charge.
Barman84 is offline
