2005 V Star 650 Second cylinder no spark...Help - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
 5Likes
post #1 of 48 (permalink) Old 07-23-2015, 12:33 PM Thread Starter
Well, here goes.
I'm not getting a spark on second cylinder.
I've gone thru the diagnose on the clymer's manual and all indicates is the igniter unit.
I've changed it twice and same.
I've switched the wires from the front primary coil to the second and I get a spark. Hence it's not the coil.
A mechanic friend said it was the pickup coil. I changed it. Same symptom.
Both sparks and caps tested and good.
The only thing left is the stator, which test fine and produces spark in both coils.
Any suggestions?
Thanks!
jjven68 is offline
post #2 of 48 (permalink) Old 07-23-2015, 02:41 PM
sonysnek's Avatar
I would star looking for a broken wire somewheres.
Sonysnek
sonysnek is offline
post #3 of 48 (permalink) Old 07-23-2015, 03:05 PM Thread Starter
I have tested the continuity of every wire and have not found any faults.
I will try again.
Thanks
jjven68 is offline
post #4 of 48 (permalink) Old 07-23-2015, 04:08 PM
you say you changed the wire from the front coil to the rear and it fired eliminating the coils i would check the wire leading to the coil.the stator supplies power to the regulator it doesnt have anything to do with the spark.
post #5 of 48 (permalink) Old 07-23-2015, 04:41 PM
Charon's Avatar
I don't know about the V-Star 650, but on Suzuki's LS650 the ignition trigger coil is mounted on the stator.
Charon is offline
post #6 of 48 (permalink) Old 07-23-2015, 05:04 PM
yea i could be wrong,everything i've heard about the stator has to do with charging.
post #7 of 48 (permalink) Old 07-24-2015, 02:21 PM Thread Starter
@Nick57, I tried the resistant of the wires from their origens to where they connect to the coil and they read well...
@Charon, by the electrical diagrams there is not such a thing in this model.
Thank for your suggestions.
This is definitely a mistery
jjven68 is offline
post #8 of 48 (permalink) Old 11-16-2015, 11:40 AM
Did you ever resolve your issue, I'm having the same problem and I've taken the same steps.
-Smokey
AlonBlakeney is offline
post #9 of 48 (permalink) Old 11-16-2015, 02:57 PM Thread Starter
@alonblakeney sorry to hear about it, but on the other hand is kind of good to know I'm not the only one with this problem. I was starting to believe that the bike is possessed or I'm going crazy.
I have put the bike away for now, but I happened to talked to a friend mechanic last Saturday that told me to make sure the pickup coil was installed correctly. He says some times he has seen it backwards.
I doubt this is the case since I remember looking at the way it goes in and there was only one way to install it. Still I am going to check it again...anything to get the demon out of this bike.
Let me known what you come up with.
Good luck!
jjven68 is offline
post #10 of 48 (permalink) Old 12-25-2015, 07:29 AM
Premium Member
RestoRider00's Avatar
What were the original symptoms ? Did it just start doing this all of a sudden, or gradually start to cut out?
RestoRider00 is offline
