2001 Vstar 650 Custom sat for around a month. Now clutch won't disengage. - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
post #1 of 5 (permalink) Old 10-10-2015, 01:47 PM Thread Starter
I'm in the process of moving so my bike sat for around a month. This Monday I took a very short ride and everything was fine. Today when I tried starting, I found the battery died. I chose to try and push start it and, to my surprise, the clutch won't disengage. The cable seems to be traveling enough and I adjusted it at the lever, still nothing. Any ideas?
Ryker is offline
post #2 of 5 (permalink) Old 10-10-2015, 06:20 PM
It's just stuck....rock it back and forth for a bit and it'll break loose. When was your last oil change?
post #3 of 5 (permalink) Old 10-10-2015, 09:48 PM Thread Starter
I tried rocking it a little. No luck. Last oil change was right before it sat for a month.
Ryker is offline
post #4 of 5 (permalink) Old 10-11-2015, 04:33 PM Thread Starter
Well, it seems you were exactly right! I rocked it a bit more (quite vigorously I might add) and started it up. Slight jump forward when starting but after that everything went back to normal!
Thanks a lot!
Ryker is offline
post #5 of 5 (permalink) Old 01-01-2016, 09:10 AM
Premium Member
RestoRider00's Avatar
Clutch plates stuck Common when sitting for long time, Dirty oil adds to the drama...
RestoRider00 is offline
