2008 VStar 1100 final drive problems - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
 4Likes
  • 1 Post By KCW
  • 1 Post By lesblank
  • 2 Post By bthompsn
post #1 of 6 (permalink) Old 06-26-2019, 07:59 PM Thread Starter
Hi there
Having a problem getting my rear wheel to mount properly. I removed it to get the tire replaced at the dealership. I followed the instructions in the Clymer manual. I took it for a test drive and noticed a slight vibration at 70kmh when I was accelerating, so I took a closer look at the rear wheel when I got home. I noticed that when I tightened the 4 bolts that mount the final gear case to the swingarm, it pulls the final gear case out of alignment, the gap between the rear hub and the final gear case is not even, back is closer than the front.
I have removed and checked everything but I can't figure out whats causing the problem, but I did notice that the distance collar may have been spinning, it had lines on, I don't think its supposed to spin in the ring gear.......
Any help would be greatly appreciated as I can't get this figured out. My next option is the dealership.
Thanks, Brian.
bthompsn is offline
post #2 of 6 (permalink) Old 06-26-2019, 08:09 PM
there are spacers that go between the wheel and the frame, - its possible one of them rolled away when you took it apart, and since you did not see it when you put it back together.. or maybe you got the parts in the wrong places
you can download the yamaha factory service manual for free from several websites in pdf files - it has the assembly drawings for taking the wheel on and off
there are also exploded drawings on websites like bikebandit, in the OEM section - you have to put in your make and model and follow a few tree branches down thru the website, but the drawing are worth the effort, very clear and useful
you should not have to line anything up taking the rear wheel off the 1100 or 650, it should come off and bolt back on easily.
Deeksvstarclassic likes this.
post #3 of 6 (permalink) Old 06-26-2019, 08:49 PM
Maybe this will help.
post #4 of 6 (permalink) Old 06-29-2019, 11:53 AM Thread Starter
Thanks for the replies.
Yes I have tried everything. The only thing I am doing out of sequence is having the axle installed before I position the wheel in the swing arm. I would have to remove the exhaust pipes to slide the axle in with the wheel in the swing arm, a major pain in the butt as I have speedster longs.
Now that I'm thinking about it, Im just going to take the pipes off and see if it helps............I will let you know how it goes.
Thanks
Brian
bthompsn is offline
post #5 of 6 (permalink) Old 06-30-2019, 03:48 PM Thread Starter
This link has a good procedure for aligning the final drive, scroll down to the tech tips section.
https://www.650ccnd.com/shaft2.htm
It didn't fix my vibration problem but it helped me get things lined up better. I will keep trying and let you know what I find.
bthompsn is offline
post #6 of 6 (permalink) Old 07-01-2019, 11:19 AM
Deeksvstarclassic's Avatar
Just to check the obvious did you have the new tire balanced?
If not you could install dynabeads which i have used on my 1800VTX. I am not promoting them but it is an option
