170/70 vs. 170/80 - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
post #1 of 6 (permalink) Old 02-19-2014, 08:56 AM Thread Starter
Elk
Elk's Avatar
170/70 vs. 170/80
I'm liking what I've read about the MC II, but it doesn't come in a 170/70. Would there be any issues other than slight change in the speedometer with fitting the larger tire on the 1300?
Elk is offline
post #2 of 6 (permalink) Old 02-19-2014, 04:38 PM
You'll lose almost 2/3" clearance between the tire and the fender. I don't know what the clearance is normally with a stock tire. The speedometer change will be towards being more accurate (around 5% lower reading than stock or 3.43 mph to the good at 65 indicated). You will also sit 2/3" higher.
The 180/65 is the more popular choice. It is slightly wider and barely shorter making it the better choice for most people. It also has the better load rating.
Edited to correct fraction error (3/4 vs 2/3) and add mileage differential.
2013 V Star 1300 Deluxe
OEM Tall Sissy Bar
Memphis Shades Fork Deflectors
Bridgestone Exedra Max Belted Tires
Baron's RSTD 7308 bar
sparkn is offline
post #3 of 6 (permalink) Old 02-19-2014, 06:16 PM Thread Starter
Elk
Elk's Avatar
Thanks for the response. I hadn't considered the wider tire.
Elk is offline
post #4 of 6 (permalink) Old 02-21-2014, 02:54 PM
Overall the 170/80 would be 1.3" taller than the 170/70. But only half that is on each side of the tire. So yeah, about 2/3 of an inch more tire under the fender. I'm sure there is plenty of space for it. Not really enough to make any huge difference in the speedo though.
sonicbeerman is offline
post #5 of 6 (permalink) Old 02-22-2014, 12:09 PM
Tonydtiger1971's Avatar
This is what I've done on my 950. So far I've been very impressed with this tire.
BLUE BIKE CLUB
Southern Chapter
2009 Vstar 950 - Ultimate Solo Seat, Full Fairing, 3-1" risers, Air Horn!!, Paladin removable sissy bar with luggage rack, Hard Bags and a Mustache Bar.
Tonydtiger1971 is offline
post #6 of 6 (permalink) Old 02-23-2014, 08:31 AM Thread Starter
Elk
Elk's Avatar
Thanks for the info. I ordered the 180/65.
Elk is offline
