Gear Oil | Yamaha Raider - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
 3Likes
  • 1 Post By KCW
  • 1 Post By nurtaeff
  • 1 Post By Highwayman
post #1 of 8 (permalink) Old 07-15-2018, 10:13 AM Thread Starter
Highwayman's Avatar
My manual calls for SAE80 API GL-4 Hypoid transfer gear oil.
Looking online I'm finding oil like [Valvoline Mineral, SAE Grade : 80W-90], [Lucas Heavy Duty SAE 80W-90 Gear Oil], [Royal Purple Max-Gear Synthetic Gear], [Bel-Ray Hypoid 80w90 Gear Oil]. Not sure what the 90 after the 80 is, if synthetic is recommended or what hypoid is - anyone?
For mad scientists who keep brains in jars, here’s a tip: why not add a slice of lemon to each jar, for freshness?
Highwayman is offline
post #2 of 8 (permalink) Old 07-15-2018, 10:20 AM
when an oil has two numbers listed it is a blend of two grades.
the 80W is the cold temp (winter) rating and the 2nd number is the 100C rating
post #3 of 8 (permalink) Old 07-15-2018, 10:26 AM Thread Starter
Highwayman's Avatar
Okay, so I need to find straight 80. Any idea about synthetic vs conventional or what hypoid is?
post #4 of 8 (permalink) Old 07-15-2018, 10:30 AM
I dont think you need to find straight 80. 70W80 or 80W90 will be fine.
Yamaha does not require synthetic oil (to meet warranty requirements).
now you got me wondering what Hypoid means -never thought about it.
post #5 of 8 (permalink) Old 07-15-2018, 10:31 AM
Hypoid: a bevel wheel with teeth engaging with a spiral pinion mounted at right angles to the wheel's axis, used to connect nonintersecting shafts in vehicle transmissions and other mechanisms.
so its "differential" oil as opposed to 'motor' oil, or 'transmission' oil...
post #6 of 8 (permalink) Old 07-16-2018, 03:41 AM Thread Starter
Highwayman's Avatar
Apparently the gears are a hypoid design which requires hypoid gear oil.
https://khkgears.net/product-categor.../hypoid-gears/
post #7 of 8 (permalink) Old 07-16-2018, 10:07 AM
nurtaeff's Avatar
Hypoid gears are typically used in rear differential/final drive where drive shaft axis is perpendicular to the wheel axle. Gear boxes normally use either spur (straight) or helical gears. Helical gears are stronger and quiter, but more expensive and impose axial load on the bearings, spur gears are simpler, cheaper, but weaker and noisier. Most of the motorcycle gearboxes have spur gears just because less radial load (motorcylce weighs less than a car and engine produces lower torque) and no axial forces which allows to make gear box case walls thinner since there is no axial load on bearing supports.
The reason to use more viscous oil in the transmission is to make sure oil film sticks better to surfaces in contact. Since lubrication in a gear box is a "mist type" and oil does not have to be pushed thru small oil passages it can be thicker.
Highwayman likes this.
Wife: 2018 Sportster Forty Eight Special
Me: 2019 Road King Special
nurtaeff is online now
post #8 of 8 (permalink) Old 07-17-2018, 07:43 AM Thread Starter
Highwayman's Avatar
GL 4 gear oil doesn't appear to be readily available. Vavoline High Performance SAE 80-90 is a GL5 gear oil that says it is compatible with gearboxes that require GL4 and hypoid gears. I went with that.
