2000 Vstar 1100 classic Oil filter relocation kit - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
  • 1 Post By lesblank
post #1 of 7 (permalink) Old 03-27-2019, 06:41 PM Thread Starter
bctrembley44's Avatar
Good Evening!
So I purchased a Baron V-Star Oil Filter Relocation Kit - BA-2640-00 Part #: 305933 Manufacturer Part #: BA-2640-00 from Dennis Kirk. There are 3 screws that hold the filter replacement part in place and the bottom screw is leaking oil. I attempted a new copper washer and also was going to try the factory screw, however it doesn't fit through the hole on the filter replacement part. Also, it seems I am going to have to relocate the rear break reservoir as that it seems to be in the way of the new oil filter. Seemed like it would be a relatively easy project. I have since put the bike back to the way it was and also leak free....but I'd really like to install that oil filter relocation kit. Thanks in advance for your feedback that may help get this thing installed properly.
bctrembley44 is offline
post #2 of 7 (permalink) Old 03-27-2019, 07:09 PM
There is a rubber oring at the bottom bolt. It's easy to forget on installation. My oil relocation block leaked a little at first. I did have the oring in but still leaked a little. I loosen all bolts slightly and touqued the bottom bolt first. Fixed problem and never leaked after that. For the brake reservoir I bent the bracket slightly used a longer bolt with washers for spacing it out some. Hope that made sense.
CanadianMohawk likes this.
post #3 of 7 (permalink) Old 03-27-2019, 07:17 PM
Might be hard to see the master cylinder but maybe this will help. The zip tie is on brake hose to keep next to frame.
post #4 of 7 (permalink) Old 03-28-2019, 09:06 AM
CanadianMohawk's Avatar
missing a pic Les? I don't see anything.
Current Bike:
2008 Yamaha V-Star 1100 Classic
Previous Bikes:
2005 Yamaha YZF-R6T
1990 Kawasaki EX-500
CanadianMohawk is offline
post #5 of 7 (permalink) Old 03-30-2019, 07:45 PM
NorthernRider's Avatar
I can see it.
Paul
2007 Vulcan Nomad
V&H exhaust
All stock except for:
Kuryakyn Grips
4" Risers
NorthernRider is online now
post #6 of 7 (permalink) Old 04-20-2019, 05:33 PM
haileymon's Avatar
Yeah, I really can’t see the BF reservoir. Is it bolted in it’s normal place? How close can I get to the headpipe before it melts in city traffic?
I was thinking about bending the bracket forward even more that’s i already did, then drilling a new mounting hole down lower, on the spar.
The front wheel is off and I’m not sure about clearance there (no fender)
...push left, lean right...
2k xvs1100 bobber, the Jolly Roger,
2k1 K1200RS, Red Ryder
2k7 St3s, Red Rocket
72 R75/5, Greta
haileymon is offline
post #7 of 7 (permalink) Old 04-20-2019, 06:24 PM
The bracket is twisted and the tab where reservoir mounts is bent some. I've had no issues in over 35k miles.
Oil Filter relocation kit (Vstar 1100) karim Engine Work 4 05-01-2017 09:58 AM
VStar 1100 Oil Filter Relocation Kit CMA Biker V Star 12 08-04-2013 03:13 PM
Which oil filter relocation kit?? stevensondrive Oil and Lubrication 4 06-29-2011 11:23 AM
Oil Filter Relocation Kit - Which One? mikegoz201 V Star 4 11-17-2010 09:43 PM
