Oil leak - Page 2 - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
 5Likes
post #11 of 18 (permalink) Old 04-18-2019, 07:33 PM Thread Starter
Pap
Thanx guys.
The bike has only done 25,000 km
I may have overfilled it before I went away. The level was on the higher side in the window, but now itís ok and still leaking.
KCW. Could you post a screenshot of that page on the manual or a link to the manual if itís online.
Pap is offline
post #12 of 18 (permalink) Old 04-18-2019, 08:34 PM
Repair manual.
https://www.google.com/url?sa=t&sour...=1555636968687
Screenshot on middle gear section.
post #13 of 18 (permalink) Old 04-19-2019, 04:53 AM Thread Starter
Pap
👍Thank you.
Iíve been catching up on some gardening today, scoring some browny points with the Minister of Finance and Pleasure.
Iíll have to wait a couple of days before I can work on the bike.
Iíll let you know how I went soon
Pap is offline
post #14 of 18 (permalink) Old 04-30-2019, 01:08 AM Thread Starter
Pap
Update.
Been to a couple of bike mechanics. One is ďsupposedĒ to be the best and the other is the local Yamaha dealership. None have seen a leak in that area.
They both told me to drop it off and theyíll have a look (and charge) because these bikes shouldnít leak in thare.
I just called a Yamaha dealer outside of town and he told me my mileage and where the leak is coming from. He was only out be 1100kms.
Apparently the oil seal in your image labeled ď9Ēleaks after 30000km. Iíve done 28900.
He even gave me the part number. Guess whoís getting my money when I upgrade?
Pap is offline
post #15 of 18 (permalink) Old 04-30-2019, 07:49 AM
That looks like a relatively simple o-ring to replace: take off the back wheel with drive shaft
pull the C clips off the universal and split it
take the nut off to remove the universal
take the 4 bolts out to remove the bearing (assume you have to drain the oil first...)
and the oring is right there.
I see a part that is not labeled on the drawing, between 8 & 9... I would assume the bearing is in the oil and the mystery part might be a shaft seal? odd that its not labeled in the diagram.
I noticed when I wash my 650 I see oil rainbows in the water draining off the bike. Wiping it down and looking under it with a mirror that area on my bike is a bit oily - enough to make the lower swing arm grungy, but never enough to drip oil on the garage floor.
My bike has 42,000 miles on it, and I dont appear to be losing any oil between 4000 mile oil changes - never have to add a drop. So maybe mine is oozing just enough to get things oily on the output side of the shaft.
Its pretty much impossible to make a shaft seal that does not at lease keep the output shaft wet with oil, as long as its not dripping or losing oil while the bike is in gear and running.
post #16 of 18 (permalink) Old 05-01-2019, 05:02 AM Thread Starter
Pap
Correction. That unlabeled part is the offending seal.
I miss understood the mechanic.
Looks like the job is easier than I thought.
Pap is offline
post #17 of 18 (permalink) Old 05-16-2019, 01:18 AM Thread Starter
Pap
Iím back.
I opted to get the bike fixed at my local dealer.
Just got it back.
They replaced the seal and found the collar (#8 on the diagram) was worn out where the seal sits, so they turned it around.
There was also a small leak at the front cylinder inspection cover and I also got them to replace the neutral safety switch.
All up it took them 5 hours.
$440 au. Iím happy.👍
lesblank and KCW like this.
Pap is offline
post #18 of 18 (permalink) Old 05-16-2019, 08:15 AM
good deal, there are only two ways to kill a Vstar engine
1. rev it up to near the red line in gear, then instead of shifting up, kick it down and let out the clutch, mechanically redlining the engine.
2. Run the engine with the oil pump sucking air, either by draining the oil and forgetting to put the new oil in the bike, or having a small oil leak and not checking your oil level every day.
I looked at a Vstar 650 last year, only 4k miles on the odo, owner said the front piston was "making a clicking noise".
Beautiful bike, asking $1500 - he rode it 35 miles away, it starting making a knocking sound, and he drove it 35 miles back on the interstate. He drained the oil out, there was only 1 quart in the engine.
It had been leaking oil for months, leaving a small puddle on the garage floor. It was also leaking when he rode it. Engine destroyed.
Best to get after any oil leaks when they start, because they will only get worse.
keep an eye on the shaft for signs of leakage for the next year or so
Since this is a rare place for a leak to happen, its possible the bearings on the shaft are failing, making the shaft loose, making the seal leak. Something to keep in mind.
When a bike has an unusual problem there might be a deeper issue.
03 vstar oil leak dazmolek V Star 2 03-27-2011 06:57 PM
Oil Leak Joker77 Oil and Lubrication 2 08-02-2010 08:31 PM
Oil leak RLRoadwarrior Stratoliner & Roadliner 5 07-24-2010 04:51 PM
oil leak bigun03 V Star 9 04-08-2010 07:26 PM
650 Oil Cover Leak PizzaIsLife V Star 1 04-03-2010 07:36 PM
