Purchased a 2008 Road star- a few questions - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
post #1 of 2 (permalink) Old 11-13-2017, 05:56 PM Thread Starter
Bilzer's Avatar
I just picked up a 2008 Road Star Silverado. I am 5' 6" tall and see that it is more of a reach to get to the foot brake. Did anyone else work to modify the brake to get it closer to the rider? Most the sites I have come across deal with EXTENDING the brake pedal?
I am also wanting to put on LED headlight and passing lights on the bike. Is there any plug and play LED set ups that folks have been happy with?
This handles differently than my 1100. How are folks liking the slow maneuvering of the Road star? Perhaps it takes some getting used to but do you all feel it is a good handling bike?
Does it need an aftermarket shock or spring to make it "two up" worthy or is it OK as it is?
Bilzer is offline
post #2 of 2 (permalink) Old 11-14-2017, 12:44 PM
afaycasaym's Avatar
The Roadstar is a big, almost 800 lb. cruiser and handles like one. It will probably take a bit to get comfortable. I'm not aware of a shortened brake lever, and I do have the extended brake lever. Not necessarily a bad thing if it's a little reach, since it's pretty easy to lock up the back wheel when applying the rear brake too hard and too fast. I haven't really pursed LEDs and am not aware of any plug and play units.
You have some adjustability with the stock shock. I would adjust this to the max and see if it works for you. I did put a stiffer spring in both my bikes which helps with bottoming out with a passenger especially on the bike I have lowered.
https://www.baronscustom.com/catalog...570/index.html
https://dd5394a0b8ca8e97ba29-abf76f3...r_all_1565.pdf
Go to 3-15 for the shock
afaycasaym is offline
