2005 1700 Road Star - gas gauge issue - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
 4Likes
  • 1 Post By divewelder
  • 3 Post By lesblank
post #1 of 8 (permalink) Old 01-19-2019, 09:28 AM Thread Starter
AsphaltWarrior's Avatar
Just purchased a 2005 1700 and seller seemed shocked when I noticed gas gauge showed E - so much so hours later we were texting about motorcycles and he said if it was an expensive fix he would pay for it - point being I do believe it probably just happened sitting up
Question, any ideas of what I should check first ? I filled it up - reads E and gas light blinks
Any help ?
AsphaltWarrior
Chris Graham
VSTAR
650V
1100V
ROAD STAR
1700 SILVARADO
AsphaltWarrior is offline
post #2 of 8 (permalink) Old 01-28-2019, 01:02 PM
Brad_G's Avatar
Any help ?
Sending units on these are known to have issues. Some guys replace them while others just keep an eye on the odometer as to when they need to stop for fuel. I don't think they're a difficult repair if you're inclined to work on things yourself.
A search over at roadstarclinic.com should give you the needed information.
Brad
Brad_G is offline
post #3 of 8 (permalink) Old 01-28-2019, 01:43 PM
divewelder's Avatar
Check the Green sending unit plug in between the gas tank and seat. Your sure the tank is full?
divewelder is offline
post #4 of 8 (permalink) Old 01-28-2019, 01:45 PM Thread Starter
Any help ?
Brad
Thanks - I removed the tank and unit but didn't help
Honestly don't think I would use it, probably be like screw it I have reserve but again just want it to work lol
AsphaltWarrior
Chris Graham
VSTAR
650V
1100V
ROAD STAR
1700 SILVARADO
post #5 of 8 (permalink) Old 01-28-2019, 01:46 PM Thread Starter
Yes Sir, I tested the plug to make sure it was getting power to and from
AsphaltWarrior
Chris Graham
VSTAR
650V
1100V
ROAD STAR
1700 SILVARADO
post #6 of 8 (permalink) Old 01-28-2019, 02:08 PM
My 2000 Royal Star has a light thats suppose to come on when the bike is down to 2 quarts or so
it doesnt work. The bike starts to stumble going up hills when there is about a gallon left in the tank on Main, because the drain is in the front of the gas tank instead of the back
always use the ON and RES positions as intended, and you wont run out unless you forget you switched it over.
If you are going on a road trip and want some insurance, get a 1 liter spun aluminum camp stove fuel bottle (looks just like the water bottles). keep that full in your saddle bag and it should be good for another 10 miles if you run dry.
If you do, you will use it 10 times to help another stranded rider, before you need it yourself.
post #7 of 8 (permalink) Old 01-28-2019, 03:30 PM
divewelder's Avatar
My 2001 will some times not reset when I fill up till I ride a few miles. Now that I think about it 13 Raider does the same thing
post #8 of 8 (permalink) Old 01-28-2019, 05:10 PM
My gas gauge reads full until it's actually about half full. When gauge reaches half full it drops to E really quickly. I've always used the odometer so gauge not working correctly is no big deal. Guess it's what you get to.
KCW, Brad_G and divewelder like this.
