Road Star Clutch issue or something more - Page 2 - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
 6Likes
post #11 of 18 (permalink) Old 05-19-2019, 02:23 PM
I think I have the Road Star factory service manual on this computer - I was able to find the free PDF download version when I was thinking of getting a Road Star last fall
if you trace the clutch cable down to the engine, usually there is a lever there. If you push it in the direction the cable will pull it there should be a little bit of free play until you feel it hit the throwout bearing, then it gets really hard to move it any further, because you will be compressing the clutch spring.
If you cant feel any free play, then loosen up the lock nut at that end, the loosen up the knurled bolt the cable goes thru until you get a bit of free play, then tighten up the lock nut snug.
There is usually the same set of adjustments at the handlegrip lever, but with less adjustment range. Its possible to max it out in one direction on the grip end, that is why its adjustable at both ends.
On some bikes you have to adjust both ends, but I dont understand why that is.
You can get the operators manual for all Vstar bikes for free, because they are free anyway. The clutch adjustment should be in the owners manual, and the service manual PDF online.
post #12 of 18 (permalink) Old 05-19-2019, 02:35 PM
I just looked, I only have the owners manual for Road Star
its says to loosen the adjustment at the grip-lever end first to get more freeplay. If you cant get enough adjustment at that point, there is an inline adjustment half way down the cable (about level with the cyllinder head) - there is no lever down at the engine end, apparently the cable goes straight into the engine block.
But its the same idea, when you push the clutch lever at the grip with your fingertip, it should move very easy (freeplay or slop) until you feel it hit the throwout bearing in the clutch, then it gets harder to push further. That freeplay should be at least 1/4" at the end of the lever as it moves.
If there is no freeplay, that is why your clutch is slipping.
Les is also correct, if you used a car motor oil with modified mpg enhancers (more slippery than standard oil) that will also make your clutch slip, because a motorcycle clutch is in the oil bath.
there way to tell if oil is ok for a motorcycle, look at the SAE lollypop logo on the bottle, the bottom half of the outer circle must be blank. Google this if its not clear.
post #13 of 18 (permalink) Old 05-19-2019, 02:40 PM
Here's screen shot of repair manual, down load free one if you don't have one. I would try this first. Looks really easy. It's easier than my 1100.
post #14 of 18 (permalink) Old 05-19-2019, 02:45 PM
KCW, we make a pretty good team. you do the typing and I do the pictures within minutes of each other. We have done this several times in the past. Pretty cool, like minds.
post #15 of 18 (permalink) Old 05-19-2019, 02:54 PM Thread Starter
AsphaltWarrior's Avatar
You Gents are Awesome
Originally Posted by lesblank View Post
KCW, we make a pretty good team. you do the typing and I do the pictures. We have done this several times in the past. Pretty cool, like minds.
AsphaltWarrior
Chris Graham
VSTAR
650V
1100V
ROAD STAR
1700 SILVARADO
AsphaltWarrior is offline
post #16 of 18 (permalink) Old 05-20-2019, 11:14 PM Thread Starter
Guys, I was able to use the knowledge and diagram you both provided to tighten up the clutch and after a 4 hour ride yesterday I would say it's fixed.
I don't know who is Robin or Batman but you are both Heros lol
Thanks !
AsphaltWarrior
Chris Graham
VSTAR
650V
1100V
ROAD STAR
1700 SILVARADO
post #17 of 18 (permalink) Old 05-21-2019, 08:12 AM
I think you intended to say "adjust the clutch" and again its weird because the clutch lever works backwards, when you pull the lever it un-clutches the engine from the transmission. When the cable is loose the clutch is tight.
to be clear, you now have some "slop" on the lever when you are not pulling it, now you can wiggle the lever end in and out freely a bit, yes?
post #18 of 18 (permalink) Old 05-21-2019, 10:23 AM
Thanks !
I'm short so I guess I'm Robin. 😂
more progressive clutch levers chedobean Motorcycle Modifications 19 09-17-2017 10:05 AM
V Star 950 clutch/frame issue bevo1981 V Star 9 09-27-2015 09:44 AM
Clutch cable stretched out so much, i suddenly couldn't take off any more Kyle76 V Star 2 09-04-2014 05:42 PM
Seeking purchase advise: V Star Custom, or something else? TriciaJD New Member Introductions 5 05-19-2014 08:16 PM
More chrome, more leather and more... MacVstar1100 V Star 13 05-07-2012 09:08 PM
