'12 Roadstar silverado S, no side or auxiliary flood lights? - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
 4Likes
  • 1 Post By lesblank
  • 2 Post By upchucks
post #1 of 8 (permalink) Old 09-08-2019, 10:02 AM Thread Starter
upchucks's Avatar
All else working but these whether on lo or hi beam. fuses good, checked for intermittent connections within the headlight shell, fuses.
How do I access the service manual to trace down the issue?
upchucks is offline
post #2 of 8 (permalink) Old 09-08-2019, 10:47 AM
Scrumdown's Avatar
Make sure all ground wires are seated tightly. Just one could make them not work correctly.
Also, are the bulbs good?
Ride Smart! Ride Often!
Scrumdown is online now
post #3 of 8 (permalink) Old 09-08-2019, 10:48 AM
Scrumdown's Avatar
Manual ... https://www.google.com/url?sa=t&sour...SwvoAAXuBsCsu_
post #4 of 8 (permalink) Old 09-08-2019, 11:01 AM Thread Starter
upchucks's Avatar
Doubtful both lamps would open simultaneously, but will check. Want the manual anyway. Thanx for heads up
upchucks is offline
post #5 of 8 (permalink) Old 09-08-2019, 11:11 AM Thread Starter
upchucks's Avatar
This concerns the Warrior, which I had previously before a truck took me out
upchucks is offline
post #6 of 8 (permalink) Old 09-08-2019, 11:27 AM
Owners manual if you need.
https://www.google.com/url?sa=t&sour...IaDQZNnerN3zM2
Scrumdown likes this.
post #7 of 8 (permalink) Old 09-09-2019, 06:39 PM Thread Starter
upchucks's Avatar
Fixed easy enough. Resold lead to switch in left housing.
lesblank and Scrumdown like this.
upchucks is offline
post #8 of 8 (permalink) Old 09-09-2019, 08:08 PM
That's great it turned out to be an easy fix, those are the best kind.
