Need some help...R* Oil Change - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
post #1 of 9 (permalink) Old 04-12-2013, 11:18 AM Thread Starter
DCrider's Avatar
I have some time today and want to change out the oil and final drive oil too.
I believe I need to run the bike a bit, then let her cool a few minutes, then drain the rear and front drain plug.
After that replace the filter, and re-install the drain plugs.
I then add 4.3 quarts????
Do I add the new oil in the dip stick port or????
Thanks
mk
“We already have enough youth, what we what we need is a fountain of smart.” 1999 Road Star Silverado & 2009 V-Star 650 Classic
DCrider is offline
post #2 of 9 (permalink) Old 04-12-2013, 12:50 PM
There's 2 oil drain plugs, but ther'es also 2 fill spots. The official procedure is to add 2qt to the dip stick port, run for 15 seconds, then add the rest. However there is a second fill spot behind the rear jug. You can add all 4 quarts there and won't need to start/stop the engine.
2001 Yamaha Roadstar
FatJay is offline
post #3 of 9 (permalink) Old 04-12-2013, 12:53 PM
Annielikeslyrics's Avatar
Thanks in advance from me too :-)
Annie
________________________________________
2003 Roadstar - "Princess"
2003 Ninja 500 R
2003 Vstar 650 Custom (sold)
Annielikeslyrics is offline
post #4 of 9 (permalink) Old 04-12-2013, 01:10 PM Thread Starter
DCrider's Avatar
FJ what's a JUG and where do I find it?
Thanks for the info.
Mk
DCrider is offline
post #5 of 9 (permalink) Old 04-12-2013, 03:27 PM
Miescha's Avatar
So I was in this strip club once . . . . wait, I already used that line
I believe the JUGS are the cylinders - the two big upper portions of the engine that are covered with cooling fins (pistons are inside each). So the rear JUG would be the rear cylinder - practically under your seat.
I don't have a Roadstar so can't shoot you a pic of a fill port, or even confirm the existence.
Good luck though!
2007 Stratoliner 1900 S {RIP July 21, 2017}
2006 V Star 1100 Classic
Miescha is offline
post #6 of 9 (permalink) Old 04-12-2013, 06:25 PM
YahMaHaw's Avatar
http://roadstarclinic.com/content/view/158/116/
You'll find more "how to" info on the Road Star Clinic forum than you could possibly need!
2000 Road Star Silverado 1600
YahMaHaw is offline
post #7 of 9 (permalink) Old 04-12-2013, 09:23 PM Thread Starter
DCrider's Avatar
Good luck though!
M, yeah I knew I was just wondering which one would hit the softball out of the park first. My bet would have been Bevo...
Thanks for the help
mk
DCrider is offline
post #8 of 9 (permalink) Old 04-26-2013, 10:06 PM
This link might help you
www.VSOC-eastanglia.org.uk/xv1600.pdf
deemudduck is offline
post #9 of 9 (permalink) Old 05-13-2013, 07:46 AM
Arty is offline
