2006 XV1700 engine knock - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
post #1 of 5 (permalink) Old 10-07-2015, 08:40 AM Thread Starter
Unhappy 2006 XV1700 engine knock
Have been trying to identify an engine knock in my Road* XV1700. Only knocks after it is well warmed up. Nothing at all when cool. Only seems to be at low RPMs. Can goose the throttle very lightly at low RPM and get the noise, or on take off it is very distinct in first, and does in the rest of the gears at low RPM as well, just not as distinguished unless really warm. Knock is very distinct, it sounds like a rod knock in a car and seems to correlate with the engine RPMs. I just bought this bike about a week ago, but I'm pretty sure the noise isn't normal. The bike has just over 14K miles on it. I've read several posts describing the same thing, but no one has the common courtesy to post the fix once they get it. They just disappear once they get their answer. Most the forums I did find it in seemed to be abandoned and can't contact the member who posted the issue to find out what the answer ended up being.
BAPPY is offline
post #2 of 5 (permalink) Old 10-08-2015, 08:09 AM
powpilot's Avatar
Bappy, I have a 2007 with about 12K on it and mine "slaps" as well. Noise increases as the engine warms and I noticed it decreased right after I changed oil. I was told that it's the piston slapping the side of the cylinder and is not uncommon in these engines. I don't think there is an easy "fix". I'm going to go to a slightly heavier oil next change and not worry about it. BTW, my engine is not using any oil at all between changes.
powpilot is offline
post #3 of 5 (permalink) Old 10-08-2015, 09:25 AM
powpilot's Avatar
This is the official tech bulletin from Yamaha 2/2/05
TECH EXCHANGE
Explanation of engine mechanical noise characteristics
XV1600/1700 Road Star models
Please use the information in this bulletin to assist you in handling customer concerns about normal engine noise
Yamaha designed the Road Star to be a very special motorcycle, the heart of which is it's enormous v-twin engine. Our goals were to build a big-bore, high torque engine in the tradition of classic motorcycles that have long been part of the American landscape. We also wanted it to have the exceptionally clean, muscular lines that without a doubt would draw attention to the Road Star.
Several engineering decisions were made to accomplish our goals. For example, we chose traditional no-fuss air-cooling so as not to have a radiator detract from the bikes clean lines. We chose proven push-rod valve actuation to give the engine it's particular style, as well as it's particular height and weight distribution characteristics. We also gave it 98-102-cubic inch displacement-bigger than many car engines-with massive internal components like a crankshaft that alone weighs a hefty 45lbs.
If a customer should question the overall engine noise level, explain to them that certain mechanical operating noises from the engine are expected, and the Road Star is no exception. It has engine-operating sounds that are inherent precisely because of the type of engine that it is. The air cooled engine design used for the Road Star, unlike liquid-cooled engines, does not have a sound deadening , liquid-filled jacket surrounding most of the sound-producing mechanical engine components. What is at issue is what are normal and abnormal noises.
Remind the customer that this is a very large air-cooled engine. Aluminum and other metal components expand when they get hot, and the engine is designed with operating tolerances to accommodate for this expected characteristic of the metal. The result is that the customer will likely hear more overall mechanical noises from the engine when it's hot and the oil is thinner.
Above all, make sure the customer is aware that the Road Star engine is proving itself to be extremely reliable and we are confident that Road Star will deliver trustworthy performance for years to come. assure them that normal mechanical noises are not the sign of impending engine failure.
Engine Noise Analysis
tapping noise from camshaft area
Normal Noise
During initial engine start-up, the customer may occasionally hear a tapping noise from the camshaft area and, within a few minutes, the noise subsides. explain that this is due to extra clearance at the push rod end before the hydraulic lifter is pumped up. When the engine is turned off and it stops in a position where one of the valves is open, that lifter will bleed down over time due to the constant pressure applied to the lifter by the valve spring. When the engine is restarted, a small amount of air may enter the lifter and it can take a few minutes for the air to bleed out of the lifter and self adjust to proper clearance.
Abnormal Noise
Constant tapping noise regardless of engine temperature - may be caused by what is called a flat lifter. if the piston inside the hydraulic lifter becomes scratched, the lifter will not be able to hold the compressed oil inside to take up the valve/push rod clearance. explain that a failed lifter will need to be replaced.
Ticking Noise from Cylinder Head Area
Normal Noise
Explain that a light ticking noise is normal due to the compact air-cooled design of the cylinder heads, which allows the sound of rocker arm loading/unloading and valve-to-valve eat contact to be heard. Clarify that the ticking noise may increase slightly as the engine gets hot where the engine parts expand and the oil thins down.
Abnormal Noise
A consistently loud ticking noise, regardless of engine temperature may be caused by an improper valve clearance adjustment. Explain that this engine is designed with 2 intake valves and 2 exhaust vales per cylinder. The single rocker opens and closes both valves at the same time. One side of the rocker is nonadjustable and the clearance is self adjusted by the hydraulic lifter. The other side is adjustable and must be adjusted so the valve contact point is the same as the other side.
Knocking Noise from Crankshaft Area
Normal Noise
When an extremely hot engine is idling, the customer may hear what some describe as a light knocking noise coming from the crankshaft area, primarily from the right side. The noise is more pronounced if the idle speed drops below 900rpm. this is a normal engine noise.
Explain that the Road Star engine is designed to produce very high torque at low engine operating rpm. Because of this low operating rpm, for the alternator to produce sufficient electrical output to support the system, the alternator is driven off of a jackshaft which is geared to the crankshaft and spins at approximately 2 time the engine rpm.
As the engine heats up and the aluminum crankcase expands, the gear lash (clearance) is increased between the alternator shaft drive and driven gear. Inform the customer that, normally, the oil viscosity dampens the gear contact surfaces and helps reduce mechanical noise. However, in this case, the oil is thin which reduces the damping effect.
Under these conditions, if the machine is put into 1st gear and the engine is loaded down below 500 rpm with the brakes applied, the described knocking noise will become even more pronounced. Explain that this is because of several factors. 1st, the ignition timing is set for 900 rpm idle speed. At below 500 rpm, the timing is too far advanced and causes early combustion which will try to force the piston down in the opposite direction. 2nd, at such low rpm, the oil pressure is also very low which affect the damping effect at crankshaft plain bearings. Combine these factors with the slow spinning alternator shaft which is juddering from the magnetic field of the alternator rotor, the engine will make some mechanical noises. Reassure the customer that this is common with any engine design and does not indicate excessive wear/clearance of components or impending failure.
Abnormal Noise
If the engine is consistently making what is described as a knocking noise regardless of engine temperature or load, convey that it may be due to a bearing or bearing surface failure at the upper or lower connecting rod or crankshaft plain bearings. if your customer is concerned that a normal operating noise is impending bearing failure, remind him or her that bearing failures get progressively worse in a short time. if the noise hasn't been getting worse or even seems to "fix itself" from time to time, it's not a bearing failure.
powpilot is offline
post #4 of 5 (permalink) Old 01-03-2016, 09:56 PM
frogmanbenst5's Avatar
The last post about engine noise is the best I came across. Thanks for putting it up.
frogmanbenst5 is offline
post #5 of 5 (permalink) Old 08-14-2017, 08:08 PM
upchucks's Avatar
My 12 does the clapping noise too, only the front jug and when hot. Concerns me picking it up and opting out on ext warranty
upchucks is offline
