03 V Star 1100 Won't Start, HELP!!! - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
 3Likes
post #1 of 16 (permalink) Old 04-29-2018, 08:47 AM Thread Starter
Cummins12V98's Avatar
I sent my bike back to our Summer location with a Friend after Bike week in Scottsdale, AZ. He started the bike (it fired right off like usual) was getting ready to ride and it died. Tried again turned over no start. Realized the fuel was off and tried again, still nothing but maybe a pop.
Good morning!
2003 V Star 1100 Classic
Finally the battery was slowing down so he put a trickle charge on it. Later he tried still turned over but no start. He added a 3amp charge for one hour while looking into fuel. He said fuel flowed out of the filter but nothing where it connects to the carbs.
He pulled the connector to the fuel pump and gave it 12V and it did nothing. Does this mean the pump is bad?
He also said there was no voltage on the supply end of the fuel pump connector. The lights work the bike turns over fine. Unfortunately I can't find my Clymer manual so I can't tell him where the fuel pump relay is located.
So I am looking for advice! He is a VERY GOOD Mechanic and has worked on bikes for many years.
Location of relay and how to test it? The gas is from CA and is about two months old but about one month ago I added plenty of SeaFoam. Really can't see it being a fuel problem.
Thanks in advance for the help on this!
Pipes, missing "stuff", re jet, Saddleman seat, ScootMod 6" forward, passenger floorboards, Clevver mod. More to come.
Cummins12V98 is offline
post #2 of 16 (permalink) Old 04-29-2018, 08:52 AM
there is a fuse for the fuel pump somewhere
post #3 of 16 (permalink) Old 04-29-2018, 08:54 AM Thread Starter
Nothing says fuel pump. I have read it's a relay that also controls a couple other things?
post #4 of 16 (permalink) Old 04-29-2018, 09:13 AM
starter relay is under the seat. most likely has a big red wire coming from the battery. according to a wiring diagram the pump is supplied from the starting circuit relay.you could run a 12 volt jumper directly to the pump and see if it starts.all the safty switches go to the relay, from the brake,clutch, and kickstand.but you say it turns over so those must be working.
post #5 of 16 (permalink) Old 04-29-2018, 10:09 AM
Mrdub's Avatar
Might something as simple as starter relay failure.. common issue on the 1100 with age.
Mark
2008 Vstar 1300a - Cobra Fi2000r (removed)- Ivan's ECU Tune - Cobra slashdown pipes- Cobra air cleaner - Memphis batwing 9" spoiler windshield - Shark Audio speakers - Pyle amplifier - Baron Custom Accessories RSTD Handlebar - Lindby Custom Multibar Highway - Tsukayu hard saddle bags - accessory 12v lighter plug - LED driving lights - switchback LED front signals.
Mrdub is offline
post #6 of 16 (permalink) Old 04-29-2018, 10:32 AM Thread Starter
Something to add is last night while talking to him he tried starting and noticed a spark. It was the red cable from the battery it was loose at the connection away from the battery the battery connection was tight. He tightened it and it made no difference.
post #7 of 16 (permalink) Old 04-29-2018, 05:51 PM
I would first load test battery, any auto parts store can do it. Second, with ohme meter check starter relay. Here's a snip from manual.
Here is link to repair manual if you need it.
https://sites.google.com/site/vstar1...ibrary/manuals
Keep us posted and good luck.
Les B.
post #8 of 16 (permalink) Old 04-29-2018, 07:25 PM Thread Starter
les blank, thanks for the info. The battery is fine it's fairly new. It's a BigCrank it spins over the engine easily.
lesblank and lesblank like this.
post #9 of 16 (permalink) Old 04-29-2018, 11:40 PM
Mrdub's Avatar
Could be bad plugs.. fouled from raw fuel.. take em out sand the tip and try em again.. raw gas will foul a plug and cause it not to spark..He might not know how to start your bike...it is carburated after all.. some bikes have quirks.
Mark
Mrdub is offline
post #10 of 16 (permalink) Old 04-30-2018, 07:49 AM
Originally Posted by Cummins12V98 View Post
....He pulled the connector to the fuel pump and gave it 12V and it did nothing. Does this mean the pump is bad?
He also said there was no voltage on the supply end of the fuel pump connector. ....
you are getting a lot of random suggestions.
If you put 12V right on the fuel pump connector and the fuel pump would not could not pump fuel
then you have a bad fuel pump. Make sure he got the polarity correct - if the pump is connected backwards it may become a fuel suck.
If there is no power on the bike TO the fuel pump as well, then maybe the bad fuel pump blew out a fuse or relay when the fuel pump failed.
If the pump wont run the bike wont run.
Something else to consider: failures are usually a single point - one thing broke.
If the bike ran before it was shipped and would not run after it was shipped, then something happened during shipment. Maybe something vibrated loose, or a tie down strap got across a wire or connector and chafed thru, or a hook snagged a cable and pulled a connector off. You can usually find a cause and effect when something gets broken.
Cummins12V98 and Cummins12V98 like this.
