650 idles but cuts out on throttle - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
post #1 of 4 (permalink) Old 05-05-2018, 11:18 AM Thread Starter
My sister also has a 650 and this is the first time she started it up this year. It idles fine but cuts out when she gives it throttle. I am thinking we need to clean the carbs?
2000 Yamaha Vstar Classic 650
2013 Victory Cross Country
SirPoonga is offline
post #2 of 4 (permalink) Old 05-05-2018, 02:26 PM
I agree that the carbs most likely need to be cleaned but also check the fuel flow at the line that feeds the carbs.
Diogenes415 is offline
post #3 of 4 (permalink) Old 05-05-2018, 03:42 PM
you could try running 4 ounces of seafoam thru the bike in a full tank of new gas
unless the bike will not run at all except at idle.
post #4 of 4 (permalink) Old 05-05-2018, 09:42 PM
you can remove the carb bowl covers with the carbs mounted, remove the pilot jets and clean them with a thin wire, you will need to file the point down on a number 2 phillips to get it to fit tightly in the screws, the brass screws are japanese industrial standard or ( JIS ) you need to get that bit to fit tight or the screw head will strip out , once you get a snug fit give it a sharp rap and the screw will spin right out. when you do get the jet out you'll see just how tiny the holes are and understand why they clog up. a grain of salt would block that hole
