1300 Won't Turn Over When Hot - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
post #1 of 4 (permalink) Old 06-16-2018, 08:52 AM Thread Starter
disco42's Avatar
2013 V Star 1300: Starts fine in the morning but after riding for awhile and I shut down, it won't immediately restart. It may turn over once and then nothing except the ominous click. Wait 5-10 minutes and it fires right up. If I push start, it'll fire up. I've replaced the battery, ensured good connections: only thing I haven't tried is trying to jump start when it won't start. Sound like a starter issue? Time to check brushes and rebuild?
Tkx
disco42 is offline
post #2 of 4 (permalink) Old 06-16-2018, 10:49 PM
arby's Avatar
Even though it's a new battery, have it load tested. They have been known to be bad occasionally.
2014 1300 Tourer. Cobra Fuel Processor, Cobra Slip-On Muffler, Lindby Multi-Bar,
Cobra PowerFlo, Yamaha Lightbar, Wolo Big Boy. Bag Guards & Trim Rails ED Seat
arby is online now
post #3 of 4 (permalink) Old 06-17-2018, 07:15 AM
baron58's Avatar
I would check the charging system, with the engine running you should see 13.7 to 14 volts at the battery. Also when starting the battery voltage should not drop below 10 volts. Do you have added on aftermarket electrical equipment?
baron58 is offline
post #4 of 4 (permalink) Old 06-17-2018, 10:56 AM
shotgun12g's Avatar
Check the starter ground and +. Corrosion can prevent good contact and does so when hot.
Be the man your dog thinks you are!
POLITICS; From the Latin word "Poly", meaning many and "Ticks", which are Blood Sucking Parasites!
shotgun12g is offline
