1300 & 950 parts compatibility. - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
 5Likes
  • 1 Post By aryj2004
  • 1 Post By jhicks92
  • 1 Post By pistolpete
post #1 of 10 (permalink) Old 07-30-2018, 11:09 AM Thread Starter
I've been looking around at various fairings and saddlebag options for my 950, and have run across several vendors that list the 1300 for a fairing/saddlebag/trunk, but not a 950. Being fairly new to my 950, I was wondering if a fairing designed for a 1300 will fit a 950. Same with saddlebag and trunk options. It just seems like there's a lot more made for the 1300, and it would be great if I could use some of those parts, but I also want them to bolt up properly. Anyone have any experience with this?
aryj2004 is offline
post #2 of 10 (permalink) Old 07-30-2018, 11:35 AM
not sure about the fairing, but i would think they would be incompatible. there are significantly different design elements between the 2 bikes around the triple tree, so i wouldn't think that a fairing made specifically for one would fit the other. no idea about the fender, but i would suspect all the mounting locations and holes would be somewhat different, though it does look like that have the same rear suspension and tire size so the fender shape may be pretty much the same. i think i would try to find a company that offers a fairing or saddlebag or trunk for both models and see if they are different part numbers.
post #3 of 10 (permalink) Old 07-30-2018, 11:45 AM
My limited experience has been that the smaller parts are interchangeable, but your larger frame parts are not. I think bevoís advice is what Iíd go for. When I bought my MS fairing for my 950, it only fit a 950, not a 1300 as it was a different part number. Thereís still several aftermarket parts places out there for our 950ís, Iíd suggest shopping as many as possible for availability and best pricing and shipping. Just my .02 cents worth.
post #4 of 10 (permalink) Old 07-30-2018, 12:10 PM Thread Starter
Thanks for the replies guys. I'll check and see if the P/N for 1300 accessories is the same P/N as the 950 accessories, and go from there. If I find anything that uses common part numbers, I'll post what/where I found it. I hadn't looked at them terribly closely, but I assumed they'd be fairly similar (though the 1300 having a radiator probably should have been a good clue that at least things up front were very different).
Keith Post likes this.
aryj2004 is offline
post #5 of 10 (permalink) Old 07-31-2018, 06:34 AM
Thereís a Facebook group of 950 owners that Iíve gotten some good information from regarding 950/1300 parts that interchange. Iím always looking for new parts houses and found a new place called Value Accessories. Jp cycles stocks quite a few accessories along with bikerhaven.net, and several others. Our forum also has a classified section that Iíve bought stuff off of.
post #6 of 10 (permalink) Old 07-31-2018, 07:10 AM Thread Starter
Thanks for the info. I've looked on JP Cycles, but haven't looked at the other sites. So much more available than when I sold my previous bike 10 years ago. I'll definitely check out the classifieds too. Thanks again.
aryj2004 is offline
post #7 of 10 (permalink) Old 08-01-2018, 12:31 PM
jhicks92's Avatar
I actually have a 1300 rear fender on my 950. The mounting points are the exact same. Just have to notch a corner in the front of the fender and drill holes for the seat latch. The front slope of the rear fender for the 1300 is different than the 950.
all my factory stuff will bolt to the 1300 rear fender (seat, sissy bar ect.)
ID:	81678   Click image for larger version
ID:	81680   Click image for larger version
2011 Vstar 950
1983 XJ750
jhicks92 is offline
post #8 of 10 (permalink) Old 08-01-2018, 12:34 PM
jhicks92's Avatar
Oh and there are few people Ive talked to who have simply bolted a 1300 fairing to their 950.
2011 Vstar 950
1983 XJ750
jhicks92 is offline
post #9 of 10 (permalink) Old 12-22-2018, 10:35 AM
pistolpete's Avatar
Can any of those people who bolted a 1300 fairing onto a 950 come forward please....love to chat with you as I'm thinking of doing the same and have questions
pistolpete is offline
post #10 of 10 (permalink) Old 01-19-2019, 11:00 PM
pistolpete's Avatar
VStar 1300 OEM fairing does NOT fit 950....just wanted to put this to bed with hard evidence....(again thats the OEM 1300 fairing...other manufacturers 1300 fairings may... like Paul Tetreaults reckless fairing).....I purchased a NEW IN BOX NEVER USED fairing and hard saddlebags for a 1300 Vstar Deluxe....the fairing does NOT fit...saddlebags DO fit ...when bolting the bottom supports first you can see it is about an inch short and does not reach the handebars....when bolted to the handlebars first it is about 1" shy of the lightbar bracket holes...now I could fab a bracket to connect the lightbar hole to the fairing mount but that still does not solve the MASSIVE gap around the light!!! Guess the 1300 light is mounted much higher on the forks than the 950.
So I'll most likely be putting this fairing up for sale for a steal real soon since I got a great deal on a package deal (fairing and saddlebags)...I'll be posting saddlebag info soon...they fit with all 1300 parts (saddlebag bracket frame and saddlebags)
ID:	83238   Click image for larger version
ID:	83240   Click image for larger version
bevo1981 likes this.
