2009 vstar 650 Mikuni carb screw size? - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
 3Likes
post #1 of 12 (permalink) Old 08-31-2018, 10:05 AM Thread Starter
I took off and cleaned my carb on my 2009 VStar 650 classic. I want to replace the little screws on all four cover plates. (16 screws, 4 in each plate) Anyone know the size and thread so I can go to a bix box store and pick some up.
I found the part numbers on a diagram but searching the part number comes up blank on the size. I dont really want to bring it to a store and "try" to match it up. I'd rather no I putting in the right size.
Mikuni contact is no help and no part number on the carb itself
Jonny Rotten is offline
post #2 of 12 (permalink) Old 08-31-2018, 12:53 PM
(8) M4-.7 pitch 8mm long (10mm long works also) socket head screws for the carb bowls
stratsurvivor likes this.
Les B.
post #3 of 12 (permalink) Old 08-31-2018, 04:56 PM Thread Starter
Awesome. Thanks ALOT. So would these work. I like the hex better than a philips head. Will the stainless screws and aluminum carb corrode each other out?
https://www.amazon.com/0-7mm-M4x10mm.../dp/B00XP5LPHE
post #4 of 12 (permalink) Old 08-31-2018, 05:57 PM
I've got Stainless screws in mine without any issues. I also use lock washers.
Les B.
post #5 of 12 (permalink) Old 08-31-2018, 06:48 PM
Charlie5320's Avatar
you do realize that lock washers puts more pressure in one spot untill you really get the screws clamped down tight. I personally would not use washers, but maybe some blue loctight if worried about them coming loose.
2009 V Star 1300, with 11,000 miles. Solo bike with a Med shield and Cobra slip on exhaust.
Charlie5320 is offline
post #6 of 12 (permalink) Old 09-01-2018, 09:46 AM
nurtaeff's Avatar
I recently rebuilt carbs on my wife’s 650 and replaced all bowl cover screws with SS Phillips heads I got from Lowe’s. I wouldn’t use hex heads because you can easily overtorque them and strip the threads.
Sent from my iPad using Tapatalk
Wife: 2018 Sportster Forty Eight Special
Me: 2019 Road King Special
nurtaeff is online now
post #7 of 12 (permalink) Old 09-04-2018, 04:48 PM
That may be the case with split washers but not with toothed, serrated, crinkle or dished type lock washers. Besides, the small amount of uneven pressure of a split washer doesn't really matter because there's no danger of it warping the carb cap. IMO lock washers are a better alternative since I don't like gumming up the threads if it can be avoided... the best option, of course, is safety wire.
Diogenes415 is offline
post #8 of 12 (permalink) Old 04-21-2019, 12:54 PM
I've seen several posts here saying to replace with 10mm screws, but what I'm assuming are the OEM screws on the carb from my '09 650 are more like 14mm. Can anyone confirm?
knm1881 is offline
post #9 of 12 (permalink) Old 04-21-2019, 01:07 PM
Here's suggested bowl screw info.
Les B.
post #10 of 12 (permalink) Old 04-21-2019, 06:56 PM
If you ride your bike in the rain often, and esp if you ride your bike in the winter when you might catch salt spray off the road, then I would be concerned about using stainless screws into aluminum.
Normally motorcycles are fair weather vehicles, and the carbs are tucked up under the gas tank - but if you leave your bike outside often where the dew will condense on everything, I would look into this further before you do something different than the factory OEM materials.
