2014 Vstar 1300 leaking fuel - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
 4Likes
post #1 of 15 (permalink) Old 09-20-2018, 07:34 PM Thread Starter
Jpgburg's Avatar
So i ride my bike to work 30 miles one way and I noticed several spots on the blacktop where i park my bike that fuel has dripped from my overflow tube. The odd thing is I parked the bike in my basement with no sign of leakage. Any ideals?
Jpgburg is offline
post #2 of 15 (permalink) Old 09-20-2018, 08:25 PM
Is your bike parked in the sun at work? The sun will heat the fuel and it expands. All tanks are vented for this purpose. When it's in the garage the sun is not on gas tank. Next time you ride to work open you gas cap to relieve any internal pressure. Then look to see if fuel leaked out, or was it less that normal, if so you know what the issue is. Keep us informed.
Diogenes415 likes this.
Les B.
post #3 of 15 (permalink) Old 09-20-2018, 08:36 PM Thread Starter
Jpgburg's Avatar
Yes it is parked in the sun and it has been hot 90+, however i never had this issue with my Vstar 1100. Could it be a my gas cap not venting correctly?
Jpgburg is offline
post #4 of 15 (permalink) Old 09-20-2018, 08:42 PM
Almost all bikes will vent fuel under the right conditions. Take a look at your intro post for another good response. I ride an 1100 and it vents from time to time. Just pop gas tank to vent before leaving it in the sun for an extended time.
Les B.
post #5 of 15 (permalink) Old 09-20-2018, 08:49 PM
Jpgburg, despite the heat we've been experiencing something's still not right about fuel leaking. Have you checked your carbs float height? If set too high it'll increase the chance of fuel venting through the vent/overflow tubes.
Diogenes415 is offline
post #6 of 15 (permalink) Old 09-20-2018, 08:50 PM Thread Starter
Jpgburg's Avatar
Forgot to mention it is fuel injected.
Jpgburg is offline
post #7 of 15 (permalink) Old 09-21-2018, 08:12 AM
If you filled the gas tank to the brim then parked it in the sun, the gas will expand in the heat and it has to go somethere.
If that is not the case, if you know the tank is not completely full, then you need to look for the leak.
Is this a California bike maybe? They have more venting/overflow hardware than bikes sold in the rest of the US. Its also possible you have a loose hose clamp somewhere on a fuel hose, and its just dribbling down the overflow tube.
If your are sure its coming out the overflow tube, if you can see it coming out, pop the gas cap and see if it stops? If it does then your tank vent is plugged up.
post #8 of 15 (permalink) Old 09-21-2018, 08:43 AM Thread Starter
Jpgburg's Avatar
Not a CA bike and Im sure its coming out of over flow tube . Is the tank vent located on the fuel cap itself? I will definetly try leaving the gas cap popped open next time i ride.Thanks to all for all the help!
Jpgburg is offline
post #9 of 15 (permalink) Old 09-21-2018, 08:52 AM
If your garage floor is concrete you will not see a gas leak on the floor. Unleaded gas evaporates away completely, leaving no trace on concrete.
The asphalt pavement on a driveway or parking lot will interact with the gas, and look discolored under a gas leak, after the gas has evaporated.
So maybe it is dripping in your garage too.
bevo1981 likes this.
post #10 of 15 (permalink) Old 09-21-2018, 09:28 AM Thread Starter
Jpgburg's Avatar
Didnt know that. What could i put under it to check? Cardboard?
Jpgburg is offline
