650 differences - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
 8Likes
post #1 of 25 (permalink) Old 10-27-2018, 05:40 AM Thread Starter
Dbmanthe's Avatar
650 differences
I'm new to the vstars, ridden them but never owned one. Are there many changes to the 650 year to year? Were there any major changes in a certain year? The reason I ask is because I'm considering a 2004 so I want to do a bit of research on the older ones.
Thanks everyone!
Dbmanthe is offline
post #2 of 25 (permalink) Old 10-27-2018, 06:34 AM
this is an older post, but it covers everthing I know about: https://www.starbikeforums.com/forum...ent-years.html
the only changes were modifying the ECU and adding the cat to the exhaust. I think the ECU changes added a throttle position sensor or a cut off switch to the carbs.
The whole drive train goes back to the Yamaha virago 535 from the 1990s. It is one of the most reliable motorcycle engines ever sold (cant say on the market anymore).
There are no design issues with the entire drive train. Early on (around 1999) a handful of bikes got out of the factory without the shaft drive splines being properly lubed with 60% moly paste, and the splines wore out - which is an expensive repair. If you check your drive shaft splines and lube them properly if needed everytime you change your rear tire, the bike is easily good for 100,000 miles with proper oil changes, plugs, filters, and valve adjustment maybe every 16 to 20k miles.
The two models are the custom and the classic (both stupid names). they have different size front wheels (custom is bigger diameter) and different fenders, and the classic has floorboards while the custom has footpegs.
The Silverado is a classic with factory windshield and saddle bags.
post #3 of 25 (permalink) Old 10-27-2018, 08:06 AM Thread Starter
Dbmanthe's Avatar
Thanks! I guess the year doesn't matter as much as the condition of a particular bike. It's great to hear about the long term reliability too. I've been going through bikes for the last couple years looking for the right one and honestly I don't like it but I think the V Star650 is the ticket
Dbmanthe is offline
post #4 of 25 (permalink) Old 10-27-2018, 08:30 AM
It matters the most if you try to put parts from one year onto another bike. I think it was around 2000 when they did the ECM and cat changes, so you cant jump an ECM or carb across those years.
Have you been riding long or is this your first bike?
The Vstar line has a lot of options out there, depending on what you are looking for.
Ive had my 650 for 6 years now. Its a great bike around town and for taking casual rides on secondary roads: 60mph road trips. To me the bike feels like it wants to go 45 to 50 something mph - it feels like it would run forever at those speeds, and a stock bike gets close to 60mpg. It will go 80mph on the thruway, it does not hit the redline till 100mph, but compared to riding at 55 I dont enjoy the 80mph thruway dash at all.
The VStar 1100 is more or less the same bike, but pumped up with a bigger everything. From 50 feet away they look almost identical, but the 1100 is more highway worthy.
From there you can jump to the vstar 1300, the royal star 1300 V4 (water cooled), which is the bike under the touring Venture bikes (except for the "new Venture" which is an all new bike).
And then there is the Road star, a 1600 or 1700 bike (depending on the year and trim version) that has one carb (on the early ones) air cooling and pushrods instead of cam chains.
I just got a 2000 Royal Star. Between that and my VS650 I have commuting and errands covered nicely with the 650, and for longer rides or when I need some pure motorcycle theraphy to put a smile on my face, I take Ursa (the she bear).
There are photos of both in my garage page on the left side of the screen.
<= click on the garage, then click on the thumbnails again in the garage page to see the full size photos.
post #5 of 25 (permalink) Old 10-27-2018, 08:35 AM
BTW, the weird thing about Vstar bikes, I can find one around here that is several years old, for about $3000 for a bike with reasonable low mileage in good condition (taken care of, good tires... ready to ride)
and it doesnt matter which one: the 650, 1100, Royal Star, Road star... once they get several years old its about the same price for a bike in good riding condition.
post #6 of 25 (permalink) Old 10-27-2018, 09:19 AM
ctrider's Avatar
The 650s are great bikes, agree with previous posts on its niche. Where are you located? I went up to a Royal Star now that my wife wants some creature comforts and would like to sell my 650
Dirt:
Holly - '93 Honda CR250
Street:
Vanessa - '04 650 Classic
ctrider is offline
post #7 of 25 (permalink) Old 10-27-2018, 09:28 AM Thread Starter
Dbmanthe's Avatar
I've been riding for about 20 years, 8 or 9 bikes. I'm not stuck on the 650, but I have never ridden the bigger ones for whatever reason. I am pretty small, 5'6" 165lbs so ergonomically I tend towards small bikes. Blessing and curse. I'll look at the 1100 more specifically, maybe ride one? Just to get a feel.
I like the simplicity of air cooling and weight saving. More because of the simplicity factor, weight saving is just icing on the cake.
I also like the idea of a V4 but for no good reason. Is there anything specific to that engine, good or bad?
Dbmanthe is offline
post #8 of 25 (permalink) Old 10-27-2018, 09:47 AM
at 5'6" a VS 650 could be perfect for you. Find one at a dealer or craigslist and take one for a ride.
Where do you live BTW, Im in upstate NY near Rochester.
Im 6' zero and I feel a little cramped on my 650, more so now that I have the Royal Star and switching between bikes.
The V4 engine is great. On my RS its 74HP, and the closest thing you will find to an early goldwing boxer.
The engine looks almost the same from the side as a 650, but its like there are two of them side by side. The engine is wider, I have to plant my feet wider, its harder to duck walk the bike around, and the bike is about 700 lbs, almost 200 lbs heavier than the 650. Unless you are a really athletic person you might find the royal star is a bit much. When its cruising it handles easily, but walking it around and riding slow you really have to respect the weight.
I call it Ursa (the SheBear) for good reasons, she has earned the name: big, strong, heavy, fast, and robust. I rolled it over on its crash bar once already doing a U turn, and there was no damage. Its just a blast to ride. WFO in 3rd gear the quad exhaust sounds like a small block Chevy V8 spooling up. All the Vstar bikes are good for 100,000 miles, and I think the V4 1300 will go well past that.
The 1100 is in between. There are some 5'6" VS 1100 riders on here (Lesblank for one) and they have no problems handing it.
All the Vstar bikes are designed for riding - fill it with gas and push the start button. If you look around this website you will see a lot of conversations about other things, but people with a broken bike that cannot be used are rare, and most of those are from old jello/gas, or dead battery with a loose wire.
post #9 of 25 (permalink) Old 10-27-2018, 10:11 AM
Originally Posted by KCW View Post
TThere are some 5'6" VS 1100 riders on here (Lesblank for one) and they have no problems handing it.
To me the 650 is a great around town bike and short interstate or 2 up riding. The 1100 you can ride all day on interstate and 2 up. I'm about 5'6 when I stand up straight and all of 125 pounds. No issues with bike size or weight what so ever. It might seem a little big at first but you woukd get used to it real quick. Good luck on your hunt.
Les B.
post #10 of 25 (permalink) Old 10-27-2018, 12:52 PM Thread Starter
Dbmanthe's Avatar
Thanks guys! I found a nice used 650 but I gotta move a bike before I can squeeze another one in. Single car garage, 4 motorcycles, 4 bicycles, 2 welders.... do want to swing a leg over an 1100.
Unfortunately (?) I'm not very wide so the v4 may be a foregone option. Recently found out I'm not a fan of wide bikes!
Dbmanthe is offline
