650 Clutch shaft oil seal - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
 2Likes
post #1 of 12 (permalink) Old 12-18-2018, 02:49 AM Thread Starter
b1pig's Avatar
Anyone ever have to replace the oil seal on the clutch shaft? I found a huge amount of silicone gooped up around the clutch shaft on the top left of the engine case. This bike had a persistent oil leak on that side and that does seem to be the source of it.
I've looked at the engine schematic. Its hard to say if I can remove that shaft without disassembly of the case. If I can pull the rod out while turning the shaft... will that work?
anyone?......
01 BMW R1100RT, 99 Fat Boy, 07 GZ250, 04 V Star 650 Classic
b1pig is offline
post #2 of 12 (permalink) Old 12-22-2018, 10:30 PM Thread Starter
b1pig's Avatar
I take it as a “no”.... I’ll figure it out. On a side note, I swapped the gears in the final drive out.
b1pig is offline
post #3 of 12 (permalink) Old 12-23-2018, 12:32 AM
Those are some nasty looking splines. Was it making any noise?
Wish I could help, but my clutch seals have been leak free.
skypupbob is online now
post #4 of 12 (permalink) Old 12-23-2018, 06:10 PM
We talked about using 60% moly paste on the drive shaft splines before, right?
Locktite version call its an anti-seize paste, but its the same thing - as long as its 60% moly.
I dont recall any recent conversations about leaking clutch shafts on 650s.
post #5 of 12 (permalink) Old 12-26-2018, 05:40 AM
I have the same problem. To fix it, unfortunately, is necessary to remove the engine case, and rear cylinder head.
Cheap part, expensive work.
Edit: in my case, the leak is not so big, so I decide to live with it.
08 XVS650 Custom - "Judith"
ISRA #33080
Delson is offline
post #6 of 12 (permalink) Old 12-26-2018, 08:29 PM Thread Starter
b1pig's Avatar
Gah!.... Thats not what I was hoping for. Well. Mine is a little more persistent. I will have to investigate further. I'm waiting to see if I can come up with the money to buy a dang table lift. I have the frame lift, but I don't trust the thing. I'll also be taking a look at the crank case vent tubes to ensure they are not plugged. If the crank case gases don't have an escape route, seals leak.... sometimes really bad. Mine is not bad idling and revving, but riding even a short distance, puts a pretty persistent film of oil down the side of the engine. Something that MUST be fixed.
The final drive was STRIPPED... there was no noise at all, LOL. My "new" ones are properly greased. I'm waiting till next week to order the new tire, tube and brake shoes for the "new" rear wheel. The old one is cracked bad around the wheel bearing. Easiest thing to do is replace it. When I'm done, the only original parts will be the final drive housing, shaft and the brake backing plate.
I did slap it together to pluck around in the yard and run through the gears a little....
While putting around the yard, I found that my size 10 foot does not fit between the heel/toe shifter on this bike. Luckily, I have a toe only shifter in my shop. I will be putting that on when I have time.
b1pig is offline
post #7 of 12 (permalink) Old 12-26-2018, 09:06 PM
I cut the heal shifter off my 650 about a week after I got it. Drove me nuts because I kept stepping on it when I moved my foot.
What lube did you get for the splines on the shaft drive. There use to be a few out there, honda had one for the gold wings and their other shaft drive bikes. I ended up getting the Loctite LB8012
this stuff:
https://www.zoro.com/loctite-anti-se...waArhlEALw_wcB
expensive stuff, like $35 for maybe 8 ounces?
post #8 of 12 (permalink) Old 12-26-2018, 09:33 PM
not sure what you mean by clutch shaft, a couple years ago someone said the oil was coming thru the case where the wires from the stator are routed. he said he cleaned them real good and sealed with rtv sealant from the inside. the case has to be exceptionally clean to stick. you might not want to put sealant inside the engine so i would think about it before committing. anyhow do a site search on cases leaking i'm sure it's been talked about before.
post #9 of 12 (permalink) Old 12-27-2018, 02:43 AM Thread Starter
b1pig's Avatar
Item #24 is the clutch rod. The seal is #23.
Its the lever on the top left of the case that the clutch cable connects to to disengage the clutch.
As for grease, I have some Loctite on order. I greased mine so it wasn't dry while I verified everything else worked like its supposed to.... and found the oil leak. So far, that looks like the only issue I have left other than tires.
b1pig is offline
post #10 of 12 (permalink) Old 12-28-2018, 09:03 AM
I pictured the shaft differently but now that you posted the drawing it seems odd that shaft would leak.
Im not sure the engine oil level is higher than that seal. Check you oil level and make sure the engine is not overfilled.
