2006 Vstar 650 classic 7"daymaker headlight install issue! - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
 3Likes
  • 1 Post By lesblank
  • 2 Post By Getterdunn
post #1 of 7 (permalink) Old 02-13-2019, 12:37 PM Thread Starter
Getterdunn's Avatar
I tried installing the headlight, couldn't quite figure it out. Re-installed the factory headlight and now it won't work either no low or HighBeam and the high beam indicator light won't come on.
Things Ive checked
Headlight fuse 15amp it's fine
I believe the headlight relay two 30amp fuses they are fine.
Now what? ?????
Getterdunn is offline
post #2 of 7 (permalink) Old 02-13-2019, 12:49 PM
Need to backtrack all changes you made. Are you getting 12 volts to headlight socket. Check all wires in headlight bucket to verify something didn't accidentally get pulled loose. There are some bullet connections in there that are easy to pull loose.
post #3 of 7 (permalink) Old 02-13-2019, 01:32 PM Thread Starter
Getterdunn's Avatar
Since I haven't run my bike for close to 4 months. I didnt realize that the headlight doesn't come on unless the bike is running. I was trying to keep her in hibernatetion until the warmer weather was here and ready to ride. So I clenched my teeth started it up and wouldn't you know it. The light works.....😀now to figure out which of the wires that are attached to the harness go? It is a halo design that also has a signal light halo that activates when the signals are turned on.
ID:	83372   Click image for larger version
bevo1981 and graybeard like this.
post #4 of 7 (permalink) Old 02-14-2019, 10:16 AM
eruby's Avatar
Originally Posted by Getterdunn View Post
I didnt realize that the headlight doesn't come on unless the bike is running..
Humm, my 2005 1100 light comes on when I turn the key. I would actually prefer it to come on when the engine is running but I switched to LED as well so I guess it's not a problem.
'05 V Star 1100 Silverado $2000
Jardine Rumblers Slash Cut Slip-ons $50
Ext. Depot Billet ORK $120
LED Daymaker Headlight from Amazon $59
LED Driving Lights attached to Stock Turn Signal Stems $29
SuperbrightLEDs High Power Brake LED w/ Brake Flasher $18
SuperbrightLEDs "Switchback" Front LED Bulbs $28
Unibar Engine Guard $35
Rear Fender Mini Luggage Rack $25
Throttle Assist $32
Cruising with the Wind in your Face - Priceless
eruby is online now
post #5 of 7 (permalink) Old 02-14-2019, 12:04 PM
I think they added the headlight relay in 2006, so the light stays off until the engine is started.
Whenever I fly in a jet, when they take off, the last thing they do is turn off the lights in the passenger cabin and turn down the air vents, it always makes me laugh.
"Scotty! Divert all power from life support to main propulsion, or we'll never get this 737 off the ground!"
post #6 of 7 (permalink) Old 02-14-2019, 02:53 PM Thread Starter
Getterdunn's Avatar
I could swear before I started messing with the headlight it came on with a key flick. Definitely going to have to research more into this. I'm wondering if I did something wrong but it's still working....
post #7 of 7 (permalink) Old 02-14-2019, 04:33 PM
mikearc095's Avatar
On my 08 1100 classic the headlight comes on when the key is turned on. Would be nice if it stayed off till the bike was running.
mikearc095 is offline
Daymaker 7" LED Headlight ?? SilvrT Road Star 12 12-27-2017 10:21 PM
2005 V-Star 7" Daymaker bcstandup V Star 4 09-22-2017 03:55 PM
5 3/4" daymaker headlight Andy27012 Stratoliner & Roadliner 2 01-24-2017 05:44 AM
"New" rider, "new" V Star. DRTDEVL New Member Introductions 6 08-03-2013 12:40 AM
What do terms "slashdown" and "billet" mean? Kookynut V Star 4 04-25-2013 03:10 PM
