1300 Passing lamps - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
 2Likes
  • 1 Post By Mfwright79
  • 1 Post By KCW
post #1 of 8 (permalink) Old 04-02-2019, 06:06 PM Thread Starter
Mfwright79's Avatar
Question 1300 Passing lamps
Okay, so, I've been looking into possibly getting a set of DRL/halo lamps to install in my passing lamps. Sadly, from what I've found, there seems to be 2 sizes of Yamaha factory passing lamps. There is a 4.5 inch and a 4.7 inch. By cross referencing part numbers, they seem to look identical, and I can't figure out which is a 4.5 vs the 4.7. I am also kind of unsure if that's measuring by internal diameter or external. Hence the dilemma I'm currently at. I could go sure thing and get new buckets then order the lights, but from what I've seen, 99.9% of buckets seem to be designed to HD specs, and I'd also have to buy new turn signals. As the weather's been extremely back and forth, along with the work schedule lately, I'm hoping someone here may have some useful info for me.
Thanks in advance!
"Those extreme-sports kids today are good, but they have it easy. Try falling off of a motorcycle going 70 or 80 miles per hour on asphalt. Believe me, nothing equals it." - Evel Knievel
*07 V-Star 1300 - Hypercharger, PCS Monster Pro unbaffled, solo riding setup*
Mfwright79 is offline
post #2 of 8 (permalink) Old 04-03-2019, 07:18 PM Thread Starter
Mfwright79's Avatar
Had some decent weather today, so I pulled one of the passing lamps out and measured.... I've got 4.7 inch housings. The three part numbers I've found for the passing lamps are:
STR4WM3510EA - I think may be the original design...possibly a 4.5 inch housing/halogen I've seen mentioned a few times.
STR4NK351001 - which appears to be a halogen bulb...can't find measurements anywhere.
and
STR4NK351000 - which seems to be my passing lamp, the sealed beam.
post #3 of 8 (permalink) Old 04-04-2019, 11:28 AM
CanadianMohawk's Avatar
This is probably a super dumb question, but what exactly are passing lamps? Do they come on with the High beams or is it a separate switch? Are they really used only when passing?
Full disclosure: My bike doesn't have these, nor do my previous two bikes.
Current Bike:
2008 Yamaha V-Star 1100 Classic
Previous Bikes:
2005 Yamaha YZF-R6T
1990 Kawasaki EX-500
CanadianMohawk is offline
post #4 of 8 (permalink) Old 04-04-2019, 12:11 PM Thread Starter
Mfwright79's Avatar
They’re kind of like fog lights. One on each side of the headlight. Mine are wired to be on when the low beam is on and off while using high beam, with an off switch in the housing in case I want to shut them off completely.
These:
CanadianMohawk likes this.
post #5 of 8 (permalink) Old 04-25-2019, 07:20 PM
Hi: I do have passing lamp however the outing fell off and is there anyway I can get the part it is Cobra passing lamp. Definitely do not want spend 350 for the brand new.
sharp859 is offline
post #6 of 8 (permalink) Old 04-25-2019, 11:14 PM
Mfwright: Are your lights factory wired to come on/go off like that or did you wire them? In my time spent in various forums that is the first time, I think, that anyone has mentioned said method.
Mine are all home-made and wired with a simple on/off switch on my left-side handle bar, so they're on or off purely at my whim.
750 Chris Here in this forum
750 Chris In VRA forum
750 Guy In VROC forum
Chris and Shim In vn750.com forum
Long retired USAF AMMO troop (74 to 95)
Fully retired now
2005 Yamaha Virago 250
2006 Kawasaki Vulcan 750
750 Chris is offline
post #7 of 8 (permalink) Old 04-26-2019, 12:23 AM
It's not factory howeever it's been one of cobra what I did I ordered cobra single light got it in Amazon.. $65 bugs. This will work for me..
sharp859 is offline
post #8 of 8 (permalink) Old 04-26-2019, 09:13 AM
My 2000 Royal Star Boulevard came with factory side lamps.
Passing lamps is a misleading name for them.
Mine have a toggle switch on the side of the right light, I can reach forward and switch them on or off, and they are always on or off.
They are normally used with your low beams, esp during day. It makes the front of your motorcycle much more noticeable to oncoming traffic during the day (from observing other bikes with them). Better than just your low beams, but not as offensive as riding around with your high beam on in the daylight.
At night they also light up the road and shoulders better than just your low beam. They are a non-focused wide angle lens, that throws the light uniformly in all directions infront of the bike.
If they are also on with the high beams (like mine) they light up the road a bit better, but a good stock hi beam with a Sylvania silverstar bulb is already pretty good.
If Im riding at night with a lot of on coming traffic on a two lane road, I usually turn them off. If Im on empty roads at night they go back on.
I google the name "passing lights" a while back and no one seems to know exactly what that is suppose to mean.
Only turning them on when you are passing a vehicle makes no sense.
If they were intended to augment the high beam, they would be call "driving lights". I had a set of those on a '74 beetle years ago, when you turned them on, it was like you turned on street lights as far as you can see down the road, like aircraft landing lights!
Keith Post likes this.
Passing Lamps taboo365 General Bike Talk 7 12-14-2010 06:51 PM
2009 V-Star 650 Classic Passing Lamps mole2 V Star 6 11-07-2010 04:44 PM
WTS-TX: V-Star 950 Passing Lamps, Saddle Bag Guards, PCS lowering Kit. flip180 For Sale 4 09-24-2010 06:52 PM
Yamaha Raider Passing Lamps norman Raider 2 04-06-2010 05:49 AM
How do you get FULL TIME passing lamps? yamamama V Star 1 10-18-2009 07:54 PM
