950 Rear Turn Signal Bulbs - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
 11Likes
post #1 of 11 (permalink) Old 04-22-2019, 05:08 PM Thread Starter
I'm wanting to put LED bulbs in my rear turn signals in my 2014 950. According to charts I've looked at the 1156 and the 12496 bulbs are the same. But the pins are off just enough that you can't put them in.
The bulb on the left is the stock 12496 and the one right is a 1156 LED. The pins on the 12496 are at 12 and 5, the pins on the 1156 are at 12 and 6.
Is there a LED 12496 I can get? All the ones I have found have the pins in the wrong spot. I don't really want to change the sockets out.
pweber is online now
post #2 of 11 (permalink) Old 04-22-2019, 06:03 PM
Hope this helps, rear turn bulb is a 7507. The 12496 you are seeing must be a manufacturing number.
LIGHT BULB types -- bulbs used in the V Star 1300
The information below is applicable within USA.
Rear Tail Light: 1157
Front Running Lights/Signals: 1157
Rear Signals: 7507
pweber and Redbird58 like this.
post #3 of 11 (permalink) Old 04-23-2019, 05:43 AM Thread Starter
Rear Signals: 7507
Thanks, helped a lot. Looking at the pictures those are exactly what I need.
post #4 of 11 (permalink) Old 04-23-2019, 11:24 AM
Premium Member
Boots's Avatar
Another thought to throw out about changing to LED bulbs is that the design of the bulb is important for your use. I bought some (non-returnable) that had the LEDs shining straight out. The bulb was mounted with it shining to the side so it was dim compared to the incandescent since the filament shines in all directions. Probably looked good for the folks on the side walk . There are LED bulbs that have a ring of LEDs that go around the perimeter and are a better upgrade.
Edit: Adding a pic of the bulbs I bought and feel ripped off for. They might be good for some configurations but not mine.
Boots
2002 V-Star 1100
Antioch, CA
You don't stop riding when you get old, you get old when you stop riding
Previous bikes:
2004 BMW K1200GT
1995 BMW 1100 LT
1970 Honda 500/4
1969 Kawasaki 500HD - 3 cylinder rocket
1968 Yamaha 250
Boots is online now
post #5 of 11 (permalink) Old 04-23-2019, 12:16 PM
Redbird58's Avatar
Les is correct. I just went through the same thing. I added the run/turn/brake kit and wanted to get the brightness of the LED bulb. All of the 1156 bulbs that I saw in the auto parts stores had the pins 180 degrees from one another. I believe it was Les who set me on the path of getting the 7507 bulbs. I did not find any at my local auto store. I had to order some on line. Kind of expensive $19.00 for the pair but I do like the way they light up the back end of the bike. Good Luck!
09 V Star 950
Be seen and be heard! Bright lights and loud pipes!
Enjoy the ride
Redbird58 is offline
post #6 of 11 (permalink) Old 04-23-2019, 04:43 PM Thread Starter
Good input. I looked at the local parts store and found nothing, ended up ordering some online taking suggestion in mind, should be here in 2 days.
post #7 of 11 (permalink) Old 04-24-2019, 06:48 PM
Premium Member
I went with the Triple Whammy™ Run-Turn-Brake Light Kit with LED's in them. I like the pre-flash and the lights are bright.
I did not get the red lens covers but instead took the stock ones and sprayed Plasti Dip on them for red covers. The picture doesn't do it justice. It's pretty bright.
lesblank and Boots like this.
2014 V-Star 950T
jianfour is offline
post #8 of 11 (permalink) Old 04-25-2019, 05:19 PM Thread Starter
The LEDs came in and are installed. World of difference, these things are bright. I had already switched out my brake light with an LED that flashes for a couple of seconds before staying on solid.
On the front I replaced the turn signal bulbs with LED switchback and really like them.
post #9 of 11 (permalink) Old 04-25-2019, 06:00 PM
Another thing I did for rear visibility was to add a LED strip to the outer edge of rack. Works good and have had many people comment positive that ride behind me. It's a LED strip designed for the rear of a pickup truck cut down to size.
Keith Post and pweber like this.
post #10 of 11 (permalink) Old 05-02-2019, 09:53 PM
I like that Les, how hard was the install ?
V Star 950 Rear Turn signal bulbs Redbird58 V Star 24 05-04-2019 09:17 AM
LED bulbs for front turn signals CC Rider Stratoliner & Roadliner 0 08-22-2017 07:26 PM
Replacement turn signal bulbs Meatwad Road Star 4 07-03-2015 11:49 AM
LED Turn Signal Advise Load Resister vs Relay vs Signal Controler Vs Combos MadZell V Star 4 04-25-2015 10:06 PM
Turn Signal Auto Turn Off Jayson Wonder V Star 8 06-15-2010 10:40 AM
