650 Risers - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
 7Likes
  • 1 Post By lesblank
  • 2 Post By NorthernRider
  • 2 Post By lesblank
  • 2 Post By DukeHam
post #1 of 9 (permalink) Old 05-23-2019, 02:09 PM Thread Starter
DukeHam's Avatar
650 Risers
I need the bar to come up and back a bit (closer to me). I'm a huge fan of Rox risers (dirtbikes) so ordered a 4" set for my new 650 cruiser. Well ... they showed up and it took all of 30 seconds to realize that the stock cables are too short to accommodate them. They mount where the existing bar is and then raises 4" from that point, too long.
Returned them and ordered a 4" set from Amazon. They showed up today and I have a concern. Bottom of the risers are flat metal. Looks like there is a rubber seal that fits around the stock setup, not sure how I can mount these risers to the bike, anyone run into something similar and have a solution? I was thinking a couple of large washers and a home made rubber seal to protect from scratches.
ID:	84186   Click image for larger version
ID:	84188   Click image for larger version
07 Vstar 650
DukeHam is offline
post #2 of 9 (permalink) Old 05-23-2019, 02:43 PM
2 or 3, 1/2" stainless washers might fix it. my risers are round so i did'nt have that problem the stainless washers are thinner but the od is a good fit.
post #3 of 9 (permalink) Old 05-23-2019, 03:07 PM
Here's a good thread talking about risers. NorthernRider used the same ones you have without issues. Maybe he'll chime in.
https://www.starbikeforums.com/forum...-question.html
JonMaz2112 likes this.
post #4 of 9 (permalink) Old 05-23-2019, 04:01 PM Thread Starter
DukeHam's Avatar
I saw that thread, he has an 1100 and I thought maybe his cable lengths would be different then mine or maybe something else was different.
07 Vstar 650
DukeHam is offline
post #5 of 9 (permalink) Old 05-23-2019, 04:48 PM
NorthernRider's Avatar
It was close, but they fit. I did have to reroute some cables and make a slight adjustment to my brake hose (turned the fitting to take out some tension) but other than that they bolted right in. I think I just removed the cables from the metal holder and moved them to the other side of the triple tree (front or back - can't recall). That gave me enough slack. I did have to go buy some bolts as the originals had a stud attached and these just had a threaded hole. Pretty sure I picked up some large washers too. Sorry I can't be more specific on the details. It's been a while, I'm getting old, and my memory isn't that great anymore lol.
lesblank and DukeHam like this.
Paul
2007 Vulcan Nomad
V&H exhaust
2000 V Star 1100 Classic
All stock except for:
Kuryakyn Grips
4" Risers
NorthernRider is online now
post #6 of 9 (permalink) Old 05-23-2019, 06:04 PM
bfrench just put some risers on a 650. Hopefully he'll see this and chime in.
https://www.starbikeforums.com/forum...-location.html
post #7 of 9 (permalink) Old 05-23-2019, 06:10 PM
Reading this thread it appears the same risers work for the 650 or 1100. Hope this helps.
https://www.starbikeforums.com/forum...ck-risers.html
JonMaz2112 and DukeHam like this.
post #8 of 9 (permalink) Old 05-23-2019, 09:33 PM Thread Starter
DukeHam's Avatar
Thanks for the thread links Les, the takeaway Coles notes are below.
Originally Posted by bluesjr View Post
I had to reroute the clutch cable and throttle cables (which involved hacksawing a cable guide). I also removed the gas tank to free up a little slack on both right and left sets of electrical cables. Not sure if that was entirely necessary, but one thread mentioned it. I also left the bars attached when I loosed the bottom bolts of the risers (19mm), so I could use the bars to pry the risers out of the trees a bit. Then with the risers still in, I removed the bars.
Originally Posted by vstar23 View Post
if you add rubber spacer where they rest againt steering tree it damps vibration
lesblank and Yamaha Pat like this.
07 Vstar 650
DukeHam is offline
post #9 of 9 (permalink) Old 05-25-2019, 01:30 AM
Hi, Guys,
My wife ordered these for me for Fathers Day - drat I have to wait - but I chose these as they are 3.5" with a 1.625 extra rise and 1.5" to the rear - and based on NorthernRiders report that the 4" fit with a bit of fiddling figured these might be better.
Plus buying from Walmart - they can be returned and they're the same thing as on eBay and only $35.00 including shipping - go figure - Walmart as my main motorcycle part supplier.
https://www.walmart.com/ip/Krator-Cu...ight/174934815
JUst finished looking at the Ultimate Seat for the 650 classic - it lowers the rider 1" and 1" forward - actually accomplishes two things - better seat and does away with the need for handlebar risers - hhhmm - only drawback is the $285.00.
Bill
2015 Yamaha V-Star XVS65A Classic
NOS purchased April, 2017
0.9 km on the odometer
bfrench is offline
V Star 650 handlebars with risers rpm121370 For Sale 0 04-25-2013 02:28 PM
650 classic pullback risers question jetoem V Star 0 08-25-2011 06:28 PM
Baron's 'Liner Risers WMacGregor Stratoliner & Roadliner 20 07-19-2011 02:30 PM
risers for 1100 custom Jbubbs V Star 2 06-14-2010 04:44 AM
WTB: V Star risers 04ctd V Star 0 04-08-2009 09:02 PM
