950 owners: mods? - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
 2Likes
post #1 of 11 (permalink) Old 06-05-2019, 08:20 AM Thread Starter
950 owners: mods?
so just bought a 2011 vstar 950 ( ALL STOCK )
looking to do some mods to get the RPM lower at higher speeds i have read a lot of the post about swapping pulleys out
few things i would like to see posted here
1 : what pulley setup you have front and rear
2 : what belt you went with if a change was needed
3 : did you lower your bike and what you used for parts
4 : what sizes rear tire are you using
5 : or anything else you may want to add
jeepregal is offline
post #2 of 11 (permalink) Old 06-05-2019, 05:28 PM
people have done this and dropped the engine at 75mph a few hundred RPM
but if you look into it further it seems to be a lot of work and money in the wrong direction
these engines are not like harley Vtwins, Vstar engines have a relatively short throw crankshaft and are intended to run at a higher rpm
generally speaking a stock vstar bike of the same displacement has more HP than a Harley. A Vstar 650 is 40HP. A harley sportster 883 is only 30HP
I understand the engine sounds like its rev'ing fast at 75 or 85mph, because it is compared to a long throw Vtwin. There is nothing wrong, it will run 85mph all day long and still go for 100,000 miles on the odo.
I dont know the HP curves for the VS950, but the VS650 hits its peak HP at 55mph in 4th gear and 75mph in 5th. If you google it your 950 is probably hitting its peak HP at a little higher speed.
post #3 of 11 (permalink) Old 06-06-2019, 04:02 AM Thread Starter
Thanks for the info I do understand that it will run at those speed with out any problem but my issues is at those speeds the vibration or buzzing gets very annoying
and when taking long trips with family and friends i seem to be always trying to catch up or looking for a 6th gear
post #4 of 11 (permalink) Old 06-06-2019, 05:54 AM
Rear tire; 180/65-16 I read you can use 180/70
I would not lower it, as I can scrape the floor boards at will (and sometimes do) - I also ride a Ninja
Being hard to change the final drive ratio is the (big) down side to belt drive - it's so easy with chain and sprockets
Rember, if you raise the final drive ratio, it'll be a little harder to start out on inclines
I keep thinking of getting a digital GPS speedometer so I don't have to look down at the tank...
HipGnosis is offline
post #5 of 11 (permalink) Old 06-06-2019, 01:36 PM
it's not to fix a problem. it's to change the ride-ability so that it feels a little smoother at highway speeds. more RPM = more vibration
According to Motorcycle USA, the 2013 Harley Davidson Sportster Iron 883 has a maximum horsepower of 45.17 at 5900 RPM.
for some reason this chart of the 950's power curve won't show: http://www.ivansperformanceproducts....%20vs%20SO.gif
post #6 of 11 (permalink) Old 06-06-2019, 05:56 PM
its been 6 years since I was thinking of getting a new Sportster 883, got the royal snub treatment by a dealer salesman, and wandered into a Yamaha dealership instead
maybe I got the sportster 883 HP wrong from memory, but if the 883 engine was scaled up from our 650, then the ratio would put it at 53HP (but its only 45HP). Maybe thats what I was thinking
either way, yamaha gets more HP per cc displacement than HD out of their engines, partly because the Vstar Vtwins are designed and geared to run at a higher rpm.
post #7 of 11 (permalink) Old 06-06-2019, 07:05 PM
Yes, the dash on the 950 is so insanely low, I have to completely take my eyes off the road in order to see it.
I raised my 950 3/4" and haven't been scraping the floorboards but very rarely. I scrapped the frame twice and that was enough for me to fix that issue. Now in florida there are no turns around here, it's like the midwest, I could lower it and not have any issues now.
patrickdk is offline
post #8 of 11 (permalink) Old 06-06-2019, 08:51 PM
^ I lived in WP Beach for 2 years in the late '70s - boring place to have a motorcycle, unless you get a dirt bike and ride out in the swamps
post #9 of 11 (permalink) Old 06-06-2019, 11:41 PM
i added the link to the 950 dyno chart that wasn't showing in my previous post.
not sure where you're getting your numbers. but if the numbers from Motorcycle USA and the 950 dyno are correct, then it shows the 950 gets slightly less HP/cc than the 883 and its max HP is reached at a few hundred RPMs lower.
post #10 of 11 (permalink) Old 06-10-2019, 09:59 AM
I understand about changing rideablitiy, but...
more RPM isn't always more vibes.
I actually raised the RPM (by lowering the final drive ratio) on my Ninja 650. It has an exhaust and a power commander. The 'sweet spot' of RPM was above 70 mph, it is now just under 70 mph.
I've got 50K on that bike - and most of those miles are at or around that sweet spot.
