Need your help on this one, folks. - Page 3 - Star Motorcycle Forums: Star Raider, V-Max, V-Star, Road-Star Forum
 53Likes
post #21 of 42 (permalink) Old 07-22-2019, 10:19 PM Thread Starter
Shawn855's Avatar
Btw, these tests were supposed to be done with the ignition off right? No power involved whatsoever ?
Deeksvstarclassic likes this.
2003 Vstar 1100 Custom
The sun's shining, the birds are chirping; it's a good day.
Shawn855 is online now
post #22 of 42 (permalink) Old 07-22-2019, 10:28 PM
Maybe check and make sure your throttle cable is lubed up good and isn't getting hung up on soething.
patrickdk is online now
post #23 of 42 (permalink) Old 07-23-2019, 04:27 AM
That is correct.
post #24 of 42 (permalink) Old 07-23-2019, 05:56 AM
GreenMtnHunter's Avatar
...Also what kind of screwdriver do I need to buy to get these tps screws off?
No kidding, right? I have forgotten what it's called; I went to my neighbor's auto shop to borrow his... I believe it is the "Torx Driver Security Bit" There are a couple sets online for under $10...but I'll bet your local Auto store has them...
Rich
Seven Stars/Tuning Forks
2018 SVTC
GreenMtnHunter is offline
post #25 of 42 (permalink) Old 07-23-2019, 09:33 AM Thread Starter
Shawn855's Avatar
Okay I adjusted my sensor to 710 closed throttle. Do I need to adjust my idle again since I lowered the closed throttle range? It was set to 1020rpm before starting the sensor job.
post #26 of 42 (permalink) Old 07-23-2019, 09:53 AM
When ever you make any adjustments on the carbs you need to resync and adjust idle. It get redundant at times but only way to keep things right.
post #27 of 42 (permalink) Old 07-23-2019, 09:55 AM Thread Starter
Shawn855's Avatar
Weird. If my idle was set to spec, then I lowered the sensor spec, and that in turn lowered my idle, then wouldnt raising my idle end up raising the sensor number again? Lol 😋
post #28 of 42 (permalink) Old 07-23-2019, 01:32 PM Thread Starter
Shawn855's Avatar
Sigh......bike handles wonderfully now, but unfortunately the noise is still there. Took it apart when the bike was still warm and tested the sensor and it showed 720 so it was within spec. Any other ideas on wtf is causing that horrible noise on warm start?
post #29 of 42 (permalink) Old 07-23-2019, 02:17 PM
have you ever push-started a vehicle?
if you take the starter out of the loop and see if it still happens or not you can eliminate or implicate the starter as the issue
Ride the bike, park on the down side of a slight hill, turn the ignition on, let the bike coast down hill in neutral up to about 20mph,
EDIT: Kick it up into 2nd gear THEN let out the clutch...
if there is no thunk when it starts, it has to be a starter issue
I cant imagine what else it could be at this point if its not the starter?
post #30 of 42 (permalink) Old 07-23-2019, 02:20 PM
just scrolled thru the thread... if you battery is weak it might start up poorly, and start up harder when the engine is hot.
just a thought - can you put a volt meter on the battery while you are starting it (anytime?) It should stay up around 11V while the starter is cranking
if its dropping down to 8 or 9V your battery is old and tired
